Check out these R35 GT-R Bad Boys.
ZMANALEX
Okay, so I have the engine out of the 35 for some essential maintenance work and decided to upgrade the Turbos when the engine was out and also upgrade the fuel pumps.
Gearbox out later tonight, however that is a different story. ;)
This with supporting upgrades already fitted will provide me with 700 bhp.
Just waiting on a few gaskets and the unit will be good for refit.
Then I will install and program a stage 4.5 map and proceed to carry out some data logging and fine tune as required.
This remote mapping caper is certainly the business.
Edited by ZMANALEX
  • Like 11
How's this work I've an ecu tek cable winging it's way to me now
Simples, just load the software to your PC/tablet/laptop using the interface and key.
Then load the appropriate base map.
Carry out the appropriate data logging.
Send your logs to your master tuner.
Your master tuner will then review the log file and make any necessary changes.
Try and get all the logs on to one file.
Edited by ZMANALEX
Awsome I've had a couple of issues so need to do some loging and send them over to Litchfield for him to look at :)
Looking good. Shame that without the built engine you will need to cap the torque, but it's very impressive what can be had from the standard engine with relative simple (bolt-on) mods. Fuelling, exhaust, induction, turbo and a remap..... So simple!
Very interested to see what a stage 4.5 car is like against mine.... Been tempted by the modded turbos for a little while now ;)
The remote mapping is awesome... So simple and it's a try and repeat process and you can have any mapper work on the car. We had a car with issues at an event and ended up changing the gearbox map at a fuel stop.
Good luck with it and lookin forward to the results!!
Base map now in and running sweet as a nut. :teeth:
i wanted to go out and do some loging tonight but havnt been able to get hold of litchfeild today
do you know if i need anything from them other than the cable dongle and software on the laptop to be able to go out and log bearing in mind the car is already tuned by them
All you require is the dongle key, cable and interface and software on your lappy.
However you will require detailed instructions from Iain on what data logging he requires from you, specific to your tune and especially WOT logs.
They pick up on the main switch board 01684 850999 but tend to ignore emails.
If you require Iains mobile then drop me a pm.
thanks for that alex ive got his mobile and called office today so he knows ive called just dont want to pester him lol
ive an idea of what hes after
my engine light is set to flash on knock detection in my v power map and it is flashing on low revs/load we need to find out why
also had error code come up the other day cant rember the code but it was random missfire or somthing so somthing isnt right ian thought could be coilpacks. but without looking at car personaly couldnt be sure.
right i shall go and fire her up and have a play :D
