simon da silva Posted July 14, 2015 Share Posted July 14, 2015 (edited) Hey Guys. Been building my 350z over this winther and this is the result so far Did a hell of alot of work on this car but the results turned out great i think. Hope you like it! BIG THANKS TO WASSO AKA IAN THE AWESOME MAN!!! He arranged a copper plated one of custom plenum spacer, Copper plated washers and a very unique Copper badge for the rear end!!! Couldent have done this without you man!!! APPICIATE IT BIGTIME! INFO ON THE CAR IS BELOW PICTURES NEW PICTURE FROM 17-2-2016 Pictures from first post! Year: 2003 Engine: 3,5L V6 4 Valves pr. cylinder - 24 Valve in total 3.498 cm3 363 Nm Torque, at 4.800rpm Max RPM: 6.200 pr. min. 0-100: 5,9 sek Limited to 250 km/t Engine Bay: - Walbro 255 Inline Fuel pump - Rare JDM Engine Harness Cover - Copper plated Custom Bolt n Washer Kit - Black Hood Dampers - Black Wrinkle painted Intake Manifold - Takeda Induction Kit - Weapon's R, Cooling and Servo Tank - ARC Oil Catch Tank, Braided hoses - Battery Opgraded to Yellow Top - AMS Lightened Pulley KIT - Nismo CopperMix Single Plated Clutch Kit - Lightened Flywheel Kit balanced to Clutch - Copper plated Custom build 5/16 Plenum Spacer - Engine Bay has been painted! Hestekræfter From Factory 287HK Current HK Estimated around 300hk with mods Wheels Avant Garde F141 Custom Build 3 pcs Split - FRONT (19x10,5) ET15 - REAR (19x12) ET18(5x114) Copper plated Center Chrome Lips Chrome Hardware Tyres Front: Nankang NS20 245/35/19 Back: Continental Sport 265/35/19 Suspension Stance n looks Gear. - Currently: XYZ Super Street True Front / rear Coilover - First in Denmark Aircup Lift kit for Front suspension ( lift about 7-10cm ) - SPC Front Wishbone Full front camber adjustment - SPC Rear Camber Arm, plus Toe Kit - Akebono 4 pot front Caliper Custom painted in Purple with copper logo's - Slotted and drilled 360mm Front Brake discs - Nismo Brake Bads - Stainless Steel Brake lines - Akebono 2 pot rear Caliper Custom painted in Purple with copper logo's - Slotted and drilled 360mm Rear Brake discs - Nismo brake pads ICE Stereo Setup: Pioneer DEX-P99RS Headunit 4 Way Aktive DSP B2 Audio Ref 6,1 2 Way front setup 2x B2-Audio Ref10 10" 600w Subwoofers B2 Audio Quattro 4x100 to run the front setup B2 Audio Zero3 1x1200w @ 1Ohm to power the subwoofers Ground Zero GZ2500.00 Gel Battery Styling Exterior: - Custom Painted the entire car in black with loads of silver in it! - 370z Sidemarkers installed in front fender instead of the Z emblem. - Custom rear blinkers and reverse light ( one of a kind ) - Custom 06+ Front lights All carbon insides Copper painted light shroud RGB Halos RGB Deamon Eye All remote controlled - Front bumper replaced with a Nismo V1, with customer Black Reflex - Rear 06+ LED Tail Lights -Custom build rear bumper Lower part of a nissan R35 GTR rear bumper has been cut and molded into the rear 350z bumper. Unique one of a kind! - Custom build stainless steel exhaust 2x2,5" -> 3" with Quad tip exit! - Megan Racing Resonated Test pipes Interior Interior: - Eveything is covered in either Alcantara or Leather. - All work carried out by AP Kabine Design - Entire car has been Sound insulated with B2 Mats - Customer Door Pads build to fit kick bass in a more optimal position - Custom Subwoofer case Underneeth Rear Strut - Extra battery installed behind drivers seat to ensure power for the stereo at all time - Entire Trunk has been rebuild to fit 2 Amplifiers. It's a stealth build so you dont notice the build at first glance Extras Retractable front Licens Plate ( Not Yet installed Edited February 17, 2016 by simon da silva 6 Quote Link to comment Share on other sites More sharing options...
Voodoo Vix Posted July 14, 2015 Share Posted July 14, 2015 (edited) Love it! have been debating bronze on the centres of my GT-Cs so a slightly darker shade than your copper Edited July 14, 2015 by Voodoo Vix Quote Link to comment Share on other sites More sharing options...
simon da silva Posted July 14, 2015 Author Share Posted July 14, 2015 These are copper plated centers, not some paint 1 Quote Link to comment Share on other sites More sharing options...
Payco Posted July 14, 2015 Share Posted July 14, 2015 (edited) Great result, well done. Something different from the norm as well. Needs a Rickdon under bonnet mirror kit now. Edited July 14, 2015 by Payco 1 Quote Link to comment Share on other sites More sharing options...
redzed8 Posted July 14, 2015 Share Posted July 14, 2015 Looks crazy nice man good work ! Quote Link to comment Share on other sites More sharing options...
simon da silva Posted July 14, 2015 Author Share Posted July 14, 2015 Great result, well done. Something different from the norm as well. Needs a Rickdon under bonnet mirror kit now. Not a bad idea, Im getting my 07 bulgde bonnet back from paint soon, then i would deff be a nice thing to install! Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted July 14, 2015 Share Posted July 14, 2015 (edited) Pulls off the quad exhaust nicely . Car looks really clean man . Great Also amazed those wheels fit over the akabono brakes !! Edited July 14, 2015 by Bodyboarder81 Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted July 14, 2015 Share Posted July 14, 2015 Great result, well done. Something different from the norm as well. Needs a Rickdon under bonnet mirror kit now. Not a bad idea, Im getting my 07 bulgde bonnet back from paint soon, then i would deff be a nice thing to install! I love it Simon and was just going to add that you need the bulge bonnet then you mentioned it. If I was not a track car I would like my car to look like thisðŸ‘ðŸ‘👠Quote Link to comment Share on other sites More sharing options...
Ebized Posted July 14, 2015 Share Posted July 14, 2015 Pulls off the quad exhaust nicely . Car looks really clean man . Great +1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted July 14, 2015 Share Posted July 14, 2015 Not even a single mention considering ALL of the hard work and negotiations 1 Quote Link to comment Share on other sites More sharing options...
simon da silva Posted July 14, 2015 Author Share Posted July 14, 2015 Pulls off the quad exhaust nicely . Car looks really clean man . Great Also amazed those wheels fit over the akabono brakes !! They are build to order with the brake scematic from the Akebono brakes.. dont got more then a few MM og brake clearance but thats enough 1 Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 14, 2015 Share Posted July 14, 2015 Now THATS my kinda engine bay stealthy but stylish 1 Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted July 14, 2015 Share Posted July 14, 2015 Stunning Quote Link to comment Share on other sites More sharing options...
ZEUS Posted July 14, 2015 Share Posted July 14, 2015 Looks amazing, really love the rear bumper. Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 14, 2015 Share Posted July 14, 2015 Looks excellent buddy. Quote Link to comment Share on other sites More sharing options...
Bems Posted July 14, 2015 Share Posted July 14, 2015 (edited) Holy cow that's nice Edited July 14, 2015 by Bems Quote Link to comment Share on other sites More sharing options...
simon da silva Posted July 14, 2015 Author Share Posted July 14, 2015 Not even a single mention considering ALL of the hard work and negotiations Text updated m8... thx 😠Sendt fra min GT-I9505 med Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted July 14, 2015 Share Posted July 14, 2015 Looks awesome!! Great attention to detail Quote Link to comment Share on other sites More sharing options...
Stutopia Posted July 14, 2015 Share Posted July 14, 2015 Looks ace. Nice job mate 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted July 14, 2015 Share Posted July 14, 2015 Great looking Zed. Honestly one of the best I've seen, ...to my tastes anyway. 1 Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted July 14, 2015 Share Posted July 14, 2015 Wow, top job buddy! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 27, 2015 Share Posted October 27, 2015 Hey Simon, i absolutely love what you've done to your Zed, you've included some beautiful touches like the copper badges. Its a shame you didn't include any interior pics as i noticed you'd included a picture in the for sale section of your gear knob and it was then that i spotted your recovered seat and sm curious as to how the rest of the interior looks. Its a rare thing that a modded Zed tocks all of the (my) boxes, but i think the work you"ve done is top drawer and tasteful. Thanks for making me green with envy. Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 27, 2015 Share Posted October 27, 2015 Oopps it been a long night and i realise i've filled This post in the wrong way round, my bad. Regards, SAM. Quote Link to comment Share on other sites More sharing options...
simon da silva Posted October 27, 2015 Author Share Posted October 27, 2015 Hey Sam. Actually, i've never gotten around to take the interior shots! But i have a mate coming over soon to help making some beautifull shots of the car! So pleased hearing these nice things about my car! Makes me love it a little bit more Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 28, 2015 Share Posted October 28, 2015 "Love it a little bit more?" Simon if i were kinky that way i'd be leaving my Azure Blue Zed at home and having an extra marital affair with your Zed, its one of the most tastefully modded Zeds i've seen on both sides of the Atlantic. SAM Quote Link to comment Share on other sites More sharing options...
