CPhillips93 Posted July 11, 2015 Share Posted July 11, 2015 So today I had a P3 service done on the Zed. One of the two advisory notes on the visual healthcheck was NSF lower suspension tie arm de-bonded (the other was rear exhaust blow, great excuse for a new one ) I have tried the searching on here and on Google, but I can't seem to get a definitive answer... can somebody help please? What part should I be looking for? And is it a job that I can do in the garage? Nissan have quoted £385.42 but I am hoping that it isn't quite that much Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
Jp606 Posted July 11, 2015 Share Posted July 11, 2015 (edited) Sounds like the bush has split on the tie rod, easy enough to change yourself but will need tracking. Can you whip the wheel of and have a look to see the damage yourself? Maybe post a picture so we can confirm which part it actually is. Edited July 11, 2015 by Jp606 Quote Link to comment Share on other sites More sharing options...
CPhillips93 Posted July 12, 2015 Author Share Posted July 12, 2015 Sounds like the bush has split on the tie rod, easy enough to change yourself but will need tracking. Can you whip the wheel of and have a look to see the damage yourself? Maybe post a picture so we can confirm which part it actually is. Ah that's cool, was planning on getting the car tracked shortly anyways! I should be able to, won't be till next weekend now or possibly Thursday :/ The Nissan guys did say that they would send over a video but haven't received that just yet. I will try and get some time to get the wheel off and hopefully get a photo! Quote Link to comment Share on other sites More sharing options...
CPhillips93 Posted July 13, 2015 Author Share Posted July 13, 2015 http://video.citnow.com/vxYS32-b-5b Not sure if that link will work but it's what Nissan provided me with. Quote Link to comment Share on other sites More sharing options...
gareth29 Posted July 13, 2015 Share Posted July 13, 2015 cant see the video, but i can see the quote!!! Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted July 13, 2015 Share Posted July 13, 2015 (edited) Ok just watched the vid , as regards to the suspension, that's the all common banana arm bush failure. Same happened to mine and I had the superpro bushes fitted at around £160 for the bushes plus a couple of hours labour to fit them. Alternatively you could get the OEM bushes for around £50 or if the ball joint has also failed on the arm a complete new banana arm is about £250. With the exhaust you could get that sleeved or if like me I found it the perfect excuse to get a stainless system. I'd avoid Nissan for theses repairs and use an Indy , where abouts are you ? Edited July 13, 2015 by SHEZZA Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted July 13, 2015 Share Posted July 13, 2015 As Shezza says avoid the dealer. We can supply a new genuine bush for £30 if the ball joint at the other end of the arm is ok this is all you will need to replace. Can also supply Superpro and Whiteline uprated bushes. Get in touch if we can help Quote Link to comment Share on other sites More sharing options...
