PAWL3Y Posted July 9, 2015 Share Posted July 9, 2015 Had a look under my car and noticed there's some scrapes on the Y-pipe. Unfortunately I can't get a better look as I don't have access to a ramp but should I be worried? In particular at the top right of the second picture. Car drives absolutely fine but it's hard to tell if it's blowing or not. Any advice would be appreciated, thanks. # Quote Link to comment Share on other sites More sharing options...
GMballistic Posted July 9, 2015 Share Posted July 9, 2015 Second picture just looks like damage to the heat shielding so I wouldn't worry about that. The first picture though is a "flexi joint", ...these can start to blow and when they do will either mean you'll need a new Y-pipe or will have to have the flexi joint repaired by having it cut out & a new one welded in place. At the moment though it doesn't look like it is blowing as I can't see any soot build up deposits although it might not be too long before it does start blowing as that is obviously a weak spot now. Just keep an eye on it for now would be my advice. 1 Quote Link to comment Share on other sites More sharing options...
PAWL3Y Posted July 9, 2015 Author Share Posted July 9, 2015 Second picture just looks like damage to the heat shielding so I wouldn't worry about that. The first picture though is a "flexi joint", ...these can start to blow and when they do will either mean you'll need a new Y-pipe or will have to have the flexi joint repaired by having it cut out & a new one welded in place. At the moment though it doesn't look like it is blowing as I can't see any soot build up deposits although it might not be too long before it does start blowing as that is obviously a weak spot now. Just keep an eye on it for now would be my advice. Thanks! Will keep an eye on it Quote Link to comment Share on other sites More sharing options...
350zedd Posted July 9, 2015 Share Posted July 9, 2015 Start saving now, so when the flexi gives up, dump the whole exhaust and go for a decent aftermarket one...Ark springs to mind. Sounds so much better than stock. Quote Link to comment Share on other sites More sharing options...
