jumping350 Posted July 8, 2015 Share Posted July 8, 2015 (edited) Finally got some time to get rid of those jdm brakes and do install at weekend hopefully...quick question,,maybe dumb ..but.. Can I do them one by one then completely bleed that one, put wheel back on and move to the next one? or is it better to change everything (callipers/lines/discs/pads) on axle stands on all four wheels at once then bleed them all afterwards? Only ask as if i get called to work and im doing one by one I can wheel car back in garage Ive done some reading also but doesnt really say in guides ive seen, plus want the easiest method of bleeding as doesnt look fun Edited July 8, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted July 9, 2015 Author Share Posted July 9, 2015 any help with this?? can i do just the fronts tommorow and bleed and then do the rears sunday and bleed them...will that be ok? Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted July 9, 2015 Share Posted July 9, 2015 I dont see why not. Technically, normally when you bleed the brakes its recommended to do them all in a certain order to ensure all the air gets out. But in the past, I have managed fine with just bleeding the one brake im working on. What I would say is that unless you have have changed your brake fluid recently, id keep the reservoir topped up and keep bleeding & bleeding until brand new fluid comes through on each wheel you are working on in order to get rid of any old stuff. Once you have done them all you can always go around them in the correct order afterwards to double check all the air is out. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted July 9, 2015 Author Share Posted July 9, 2015 thanks rabbitstew I might do them in brake bleed order, then at least im following the procedure..kind of! Havent had fluid changed in a while so will get a couple of litres...hopefully wont be to painful Quote Link to comment Share on other sites More sharing options...
