*** TORQEN *** TORQEN S wheel spacers - IN STOCK!
Adrian@TORQEN
Made from 6061-T6 low pressure Aluminium die casting. The studs are 40Cr steel with a strength of 10.9 grade, SGS certified. Lug nuts are made from 35# Steel with a strength of 6-8 grade.
Anti-Rust level is 24-36 hours NSS(Neutral Salt Spray) test.
Machining precision: Circularity: 0.02mm, Perpendicularity: 0.03mm, Parallelism: 0.03mm, Concentricity: 0.04mm, PCD true position: 0.02mm
The TORQEN S spacers are hard anodising surface treated, in black.
Available in 15mm, 20mm, 25mm and 30mm. Custom sizes available on request.
Also check the TORQEN R wheel spacers.
Edited by Adrian@TORQEN
I'm definitely in for a set but need help on deciding what set up to go for. I have Rays and already have a set of 20mm spacers.
What are the differences between running 15/20 20/20 20/25 front/rear in handling and reliability terms?
Thats quite a big CNC miller that is being used there!
I currently have the original alloys on my zed (not the rays), I am not sure what they are called but what spacers would you recommend so that my wheels looked flush with the arches? Does spacing the wheels affect the tracking/wheel alignment at all?
any news on when these will arrive? getting excited :teeth:
Bump for this. However in the opening post it states August so fingers crossed thats still the case.
20 front 25 rear is the norm for standard alloys. I've gone 20/20 however to keep the ratio same front and rear. Fitting spacers will not impact your tracking/wheel alignment, whatever it was before will be the same afterwards.
Edited by Sargara
