xanhugh Posted July 6, 2015 Share Posted July 6, 2015 Hey folks, does anyone know the exact location of the alarm control box? Both of my keyfobs stopped working. I can still unlock manually but doing so sets off the alarm until I put the key into the ignition. I've gone over the reprogramming with 6x key to on, flashing indicators, key back to on, but the final step of holding unlock+lock x3 does nothing. When I put the key back to on position the lights flash again three times which usually indicates that the car is back out of programming mode and into normal use. Nothing happens with either keyfobs programmed individually or both in the same session. Both keys regardless of being in the ignition or not. Both keys worked fine and stopped on the same day. It would seem to suggest the fault is with the alarm control box not receiving transmissions from the key-fobs. I've come to the conclusion that I may have nudged loose the alarm antenna but don't know the location of it. Can anyone help with the location of the alarm control box please? I've searched forums and google without success. Thanks in advance Quote Link to comment Share on other sites More sharing options...
