Welding tips?
Commander
I bought a Clarke 90 gasless mig welder a few years ago and aside from welding up a trolley for it from 3.5mm angle iron, I've not used it.
I've got aspirations of fixing up an old car of some type (it's early days!) so figure I should sort my welding skills out... Here's my very first effort on some 0.5mm steel that I cut up and tried to weld back together. Blew through it a few times, some I was able to fix, others I made worse! :-)
I know butt joints like this aren't the easiest place to start, but if anybody has any tips I'll gladly take them!
Edited by Commander
That doesnt look bad. The best tip I picked up was to reduce the risk of blowing thru like that was to lean the welding tip in the direction youre going 45 deg or so - the opposite of what my old man told me!
Hello,
i am a maintenance engineer and do loads of welding, MIG, TIG ,ARC and once in a blue moon gas.
Are you definitely using gasless mig wire?
Looks like a gas mig with no gas on that's all.
As gasless MIIGs rely on flux in the wire to keep out the oxygen, rather than a separate gas shroud,used in gas MIGs, it maybe that you have the wrong wire.
With thin stuff like car body work, you want very low amps, and try spot tacking and fill in between to minimise distortion.
If your welder will take gas as well, it's better to use gas, an Argon/CO2 mix is best such as Cougar 5
It is better at keeping out the oxygen and also cools the weld
Setting the MIG is 60% of the battle, 20% practise, 20% ability
If you know someone who can weld ask them to come and show you a few things
Other than that, College is a great idea, good old You tube for tips
As already said slight weave, weld away from yourself as you can see where you are going, a decent mask also helps especially as you get a bit older and your eyesight aint what it used to be!
Rust is an insulator so clean as much off before you start. It'll burn off, but can be hard to strike
Well ventilated area as there are some nasty things in stainless and galvanised coatings especially. Galv also spits like hell
Cover your arms and don't wear a v neck t shirt because you'll get terrible sun burn on exposed skin and V neck T shirts are for girls, not blokes!
I tend to hold the end of a nod down mask as I was brought up on hand helds and it steadies my hand, but whatever feels comfortable
I have a guy who works for me uses both hands on the torch, works for him
I also like plenty of background light
Practise with different wire feeds and currents and metal thicknesses, the more practise the better you'll get, it's not rocket science, just touchy feely
The thinner the metal the quicker you need to move the torch as well
Start on thick stuff and work your way down as you get the hang of it
After a few weeks you'll be welding Kit Kat wrappers back together!
Once you can join two bits of soggy bog paper upside down, you've cracked it
Ideally you want to blend the two pieces of metal together, the wire should just replace the vaporised metal, not stick it together
You want good penetration (Don't we all), so you want to see the weld just coming through the back
If you can get the pieces flat or an inverted V, that makes things easier, up welding and upside down welding is much harder.
Keep your tips clean(Oooooh Matron) and replace regularly, the right size for your wire.
Keep your wire dry and rust free too if it's kept in a shed or garage
There are some good cheap MIGs out there now, there's no reason why you can't get some ok results at home
As with most things the more bucks you have the better the bit of kit you'll get
500 notes buys an alright TIG for home use or a great MIG.
TIGS are the boys on body work, but a cheap MIG is an ok start and you will be able to get it to work for you
Forget ally welding, you'll get nowhere with a cheap MIG and that stuff
  • Like 3
Excellent advice.
You've started with thin stuff which is much harder. Get a few bits of 2mm to practice on to build your confidence up.
Get the best mask you can. Seeing what you are doing is half the battle. A proper pair of welding gloves.
Practice and know what is going wrong. Not enough penetration, wire speeds, bad earth, etc.
More importantly and stating the obvious, always check nothing is smouldering away. ready to catch fire when you pack up and go back in the house!
Great advice above from san marino looks like he`s covered it all. Defo get an auto darkening welding mask it will make all the difference.
Got a 135 mig and it gets me out of trouble. Its one of those bits of kit that you might not use a lot but so handy when you need it. Would`nt be without one :thumbs:
Cheers chaps, plenty to be going at here!
Keep practising and go on a college evening course :thumbs:
I have already looked in to this :) and there aren't any :( not unless I have 6 weeks spare and want to learn to stick weld an oil rig or something daft...
Hello,
I'm using some SIP Flux Cored 0.8mm wire I picked up from Halfords and with the polarity reversed on my MIG for gasless welding. The welder will take gas, but I'm too tight to buy some - especially as those little disposable bottles seem quite expensive and the last one I had was spent in about a minute... Maybe I need a better regulator or something - any idea what sort of gas flow rate, pressure it's supposed to use? :-/ I've got some plain 0.8mm mild steel wire too, but it just seems to make big mounds on top of the metal rather than penetrating in to it so I've set that aside to practise on another time.
For these thin bits I'm running it at really low-power and slow feed rates. I was playing around with the settings to see what's what (cos I really do have no experience!) and it seems pretty sensitive really - fiddle around too much and all sorts of stuff goes wrong - loads of splatter, arc seems to go on/off really fast, blow through, weld piles up on top, etc... I guess it's just experience, so hopefully I'll get there with more practise time... plenty of scrap metal in my garage to be going at!
That bit of welding above was done horizontally and vertically - fancied a challenge :) horizontal welding was certainly the easier of the two. I've got an autodimming mask which seems ok and I use both hands on the handle of the welder - seems more stable to me.
Welding Kit kat wrappers? You're showing your age - they're plastic these days! ;)
I'm not getting in to Ally welding with the MIG, just steel for now...
I was lucky enough for work to allow me to do a day release course for two years, tig is deffo best for thin plate work and keeps the warping down, if using a mig I do spot tacking, first to get the panel fixed in place, then every 1 to 2 inches, then fill in the short gaps, alternating around the panel to allow the last section to cool down, it keeps the heat in localised patches and minimises warping.
I don't like gaseless wire but to get around the small and pricey CO2 bottle costs, try asking a friendly landlord for a pub CO2 bottle and regulator, you will then need to add some plastic pipe and rig up an adapter to your machines gas regulator, but the bottle will last for months even when used daily.
BOC will rent you a large bottle of CO2 for around £8 a month I believe, refill charge isn't much either.
Don't even need to rent on a contract now :)
I used to do that but now you pay a deposit on a bottle keep it as long as you want, get it refilled when you want and they give you the deposit back when you return the bottle :thumbs:
Sweet! URL?
Sweet! URL?
Forget that - found a BOC outlet down the road from me.
Ive got both a mig gas welder & an arc welder, but never really had to use my mig much until last year when I decided to start repairing my project car. It involved bodywork - replacing sills etc, patching things up. I was using 0.6mm steel sheets. I taught myself easily enough just by watching a few youtube videos and practising on some new clean metal. As others have said, a lot of the problem is setting the welder up right. Mine has some example settings in the manual which werent far off and it was just a case of practising a few times in order to get the hang of what speed I needed to move the wire and in which direction.
Once you start welding on an actual car its a completely different kettle of fish as 9 times out of 10 you may struggle to get a clean surface to weld on, or be hanging upside down under the car. Besides the actual welding, make sure you wear gauntlets and if you dont wear a long sleeve top you`ll end up with a lovely welding tan. (as I found out :lol:)
After welding half my project car up im getting quite good at it now, and even managed to sort the old lawn mower out which broke in half after some "enthusiastic" grass cutting. :thumbs:
