350z with seized engine
richmprice
Compression tested all and were equal.
Haven't looked at MAF didn't think it would create a misfire. Do they on zs
Since you've narrowed it down to a specific cylinder I wouldn't have thought it was the MAF. But might be worth a check?
Fuel injector ok on that cylinder? Can't really think what else it'd be. It's getting proper spark, no loss of compression, correct ratios of fuel and air assuming injector and maf isn't faulty.
Edited by TT350
Just been back out too it.
I've only bloody put the coil packs on 4&6 back to front. Classic.
After all the work schoolboy error.
Chuffed though it finally roars.
Awesome!!
I had a moment like this with a motocross bike. Wouldn't start for love nor money. Changed the plug. Lead. All sorts.
Drained the carb one evening and a load of red oil came out. Flooded with 2 stroke!
Kicked it over and zing!
Managed to get the bumper and other stuff on I needed too.
So I went up the road and I got an engine light, esp and abs lights.
Also the revs counter went mental after 5k but actual revs didn't real fluctuate.
And it crunches in nearly every gear.
I'm starting to think that this wasn't just an engine issue.
Will scan it and post the codes
Ok so I have fitted a ne OE crank Sensor today and it has sorted the revs jumping at 5000rpm. There is also a lot more power now.
I also scanned the abs unit too and found the steering angle sensor was 387` When the wheels were straight. So I took the steering knuckle off and turned the steering wheel until the angle became 0ish. Took me a few Gos to get it right.
But now I have no lights on the dash.
Just a crunchie gearbox.
It does improve if you change gear abnormally slow.
Does anyone have an idea. Is it definitely the syncros.
Good save and good work!
Is it smooth if you rev match?
If the synchros have been worn for a while and it has been forced then the shift collar/gear teeth can become deformed.
You can get syncros from the US for a reasonable price.
https://conceptzperf...pe=NIS350&CA=34
How much does a good used box normally run?
