Flange rusted away - suggestions please?
David Booth
Hi all,
noticed a blowing from my exhaust, so nipped to Kwik-Fit where we found out the flange that connects the mid section to the back box, has rusted away.
Kwik-Fit reckon I have to buy both the mid section and back box to rectify, at around £600.
However - and I am a non-technical person - would/should it be possible to sleeve/weld the gap left by the deteriorated flange and save a lot of money?
Apparently, it is a common 350Z fault, caused by a non-staninless steel connecting pipe - so presumably other members have been affected by the same problem?
As ever, your help, advice, experiences and opinions would be MUCH appreciated.
Thank you,
david
I'll do that now: thank you!
Did you find anything?
£80 full system here: http://www.350z-uk.com/topic/98090-oem-exhaust-and-y-pipe/
£220 Scorpion exhaust: http://www.350z-uk.com/topic/94947-stillen-y-pipe-and-scorpion-exhaust/
Worth a PM to see if either are still for sale.
Fyi ~ that is a common place for the exhausts to go on the 350's. It's exactly where mine went some years ago but as I was keeping mine I went for a new full stainless steel system from Invidia. ;)
