Creaking noise turning left and dodgy looking suspension
jimboy2
I have a new squeak. When turning left only the car creaks. So I'm guessing all weight is transferred to the OS, so looked under car and seen this.
Which doesn't look good, as other side looks like this
Now on my last garage visit I was told that the bushing was collapsing. Has said bush now collapsed??
Is it safe to drive like this? Am I going to do any more damage?
Edited by jimboy2
Yes it's that's shot mate :(
Had mine done at H-dev and fitted with upgraded ones
I'm no mechanic but I would say its safe to drive but will need sorting sooner rather than later , I would also suggest doing both sides as well .
Thanks mate.
Can you remember what parts you used? White line? Will get both sides replaced defiantly as the other side can't be far off the same condition.
Ya it was the super pro ones ...... H- dev had them in stock and fitted in a couple hours if I remember . Asked them check the car all over when it had the charger fitted and they noticed one side was almost shot . Probably could have got away with it for a bit longer but while it was with them it made sense to get them done . Can't say I feel any difference though .
