Z_Hass Posted June 24, 2015 Share Posted June 24, 2015 (edited) Hi all, the brakes on my 350z are squealing at low speed when hot. I took it to my local mechanic and he cleaned/applied copper grease, and then it was good for a couple of weeks before it started to squeal again. Pads are not low. Any idea how/where I can sort this out. Am based in Surrey. Thanks. Edited June 24, 2015 by Z_Hass Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 24, 2015 Share Posted June 24, 2015 Worth calling the guys at Abbey Motorsport if you are in Surrey they are based in Oxted. 01883-732331 Could be shims or pad contamination a number of things worth giving them a shout. Quote Link to comment Share on other sites More sharing options...
Z_Hass Posted June 24, 2015 Author Share Posted June 24, 2015 Thanks mate, I'll give them a call. See if they give me a better solution! Quote Link to comment Share on other sites More sharing options...
S7nny Posted September 15, 2015 Share Posted September 15, 2015 What was the outcome here? Quote Link to comment Share on other sites More sharing options...
Kraziekatz1 Posted September 15, 2015 Share Posted September 15, 2015 Yes, I'd be interested as well. The brakes on our Scooby squeal like crazy and had them checked over but nothing found. Grease didn't help. Quote Link to comment Share on other sites More sharing options...
Tea and wax Posted September 15, 2015 Share Posted September 15, 2015 I've had a fair few pads and discs combination on my old car, everything from stock to drilled, grooved and coloured. With brand new pads in my old one used to squeal under braking so in the end I took them all out and removed the arm that makes contact with the disc. That shut it up Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Marcus01 Posted September 15, 2015 Share Posted September 15, 2015 Fit sticky backed shims on the back of the brake pads and refit. Quote Link to comment Share on other sites More sharing options...
brillomaster Posted September 15, 2015 Share Posted September 15, 2015 would need to know what the pads are... its perfectly normal for a race pad to squeal at low speeds when hot. Quote Link to comment Share on other sites More sharing options...
DonCool Posted September 15, 2015 Share Posted September 15, 2015 I'd love to get my squeal problem sorted. It just about drove me round the twist last Summer and then I had all new discs and pads fitted in February. Have had the same problem this Summer, although not quite as bad - probably due to the fact the weather has been worse (the squeal is never as bad in Winter). Am going to add the suggestions above to my annual service snag list (thanks T&W and Marcus for your advice). Hopefully, I'll get it sorted out this time round! Quote Link to comment Share on other sites More sharing options...
S7nny Posted September 15, 2015 Share Posted September 15, 2015 I have the GT version so Brembos all round Quote Link to comment Share on other sites More sharing options...
cphil40381 Posted September 17, 2015 Share Posted September 17, 2015 I had a bit of squealing from my brakes as well, pads were getting to the end of their life and the discs were pretty shot! Switched over to hawk ceramic pads and stoptech slotted discs - same as what octet is selling at the moment. No squeal now, also the brake dust is minimal! Quote Link to comment Share on other sites More sharing options...
valy Posted September 17, 2015 Share Posted September 17, 2015 gosh...I got this now as well on my new Z GT...new aftermarket brembo pads fitted with new shims and it does squeak sometimes... like wth Quote Link to comment Share on other sites More sharing options...
MDMetal Posted September 17, 2015 Share Posted September 17, 2015 The nice pads have a soft material on the back of the pads so shims aren't needed (I've hawk ceramics) The cheaper one's don't (whatever my old ones are) and so shims are needed with grease either side. I had this the first time I swapped my pads and shims fixed it instantly. This time I bought nice pads and don't need the shims anymore (should probably clean em and sell them!) Quote Link to comment Share on other sites More sharing options...
valy Posted September 17, 2015 Share Posted September 17, 2015 thanks will give this a try and grease the shims both sides Quote Link to comment Share on other sites More sharing options...
Wendy Posted September 17, 2015 Share Posted September 17, 2015 I too have squealing brakes at times, but note it is when gently applying the brake pedal only. I thought about just jumping on the brakes but as this is not always possible and invariably not safe either, I will try some of the suggestions above too. Quote Link to comment Share on other sites More sharing options...
veilside z Posted September 18, 2015 Share Posted September 18, 2015 Can try taking the edge off the pad on a grinding wheel. Quote Link to comment Share on other sites More sharing options...
TT350 Posted September 18, 2015 Share Posted September 18, 2015 My brakes always squeeled. Quote Link to comment Share on other sites More sharing options...
daveallen1999 Posted September 18, 2015 Share Posted September 18, 2015 I used to get a loud squeel from my front pads, Ferodo DS2500. Until I bedded them in on a track day. Quote Link to comment Share on other sites More sharing options...
OliSmudge Posted October 26, 2015 Share Posted October 26, 2015 Hi guys. Just had a read of all your comments cause I've got a horrendous squeak coming from my front brakes. They've squeaked a bit since having the car (2 and half years) but I've just changed all round discs and pads (pagid discs and brembo pads) and now the noise is almost unbearable, it's so high pitched at a certain point of braking! I've just fitted anti squeal shims to the back of the pads but the noise is still there, possibly even worse! Any other ideas from what's already on this thread? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Mikey Thompson Posted October 28, 2015 Share Posted October 28, 2015 Hi guys. Just had a read of all your comments cause I've got a horrendous squeak coming from my front brakes. They've squeaked a bit since having the car (2 and half years) but I've just changed all round discs and pads (pagid discs and brembo pads) and now the noise is almost unbearable, it's so high pitched at a certain point of braking! I've just fitted anti squeal shims to the back of the pads but the noise is still there, possibly even worse! Any other ideas from what's already on this thread?Thanks in advance Have you added copper slip/grease to the back of BOTH sides of the shims? Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted October 28, 2015 Share Posted October 28, 2015 Where do you buy the shims? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted October 28, 2015 Share Posted October 28, 2015 We keep them in stock Fronts http://www.clarkmotorsport.co.uk/parts/Brake-Pad-Shims--Front/112814 Rears http://www.clarkmotorsport.co.uk/parts/Brake-Pad-Shims--Rear/112813 Quote Link to comment Share on other sites More sharing options...
philw99 Posted October 29, 2015 Share Posted October 29, 2015 I'd ordered shims from Ewen for my 350, stopped them squeaking Quote Link to comment Share on other sites More sharing options...
