Masa Posted July 14, 2015 Share Posted July 14, 2015 So for clarification, replacing the OEM HID's with the sellers preinstalled option would solve the incompatibility, however they would not be legal as the auto levelling won't work...? Or does the preinstalled option have the 8 pin connector with the auto levelling? If no one can answer I shall ask the seller and post up responses for others Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZedManTID Posted July 14, 2015 Share Posted July 14, 2015 (edited) The lights come with a 6 pin connector regardless and are not auto levelling, you will lose that function. With regard to legailty, I don't think it is illegal to not have it when they can be adjusted manually. I went for the preinstalled HIDs as compatibility was a concern. Safe bet I'd say is to go for the preinstalled HIDs as we know the lights will arrive in a plug and play state for a JDM car. If your 350 is a UKDM the original 8 pin connector can be swapped over/rewired to replace the 6 pin and they will become plug and play. Hope this helps Edited July 14, 2015 by ZedManTID Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 14, 2015 Share Posted July 14, 2015 just be aware might fail mot as 99% of aftermarket headlights even if sold by a UK supplier are for LHD Quote Link to comment Share on other sites More sharing options...
ZEUS Posted July 14, 2015 Share Posted July 14, 2015 On 13/07/2015 at 18:14, gort said: On 13/07/2015 at 18:09, BulletMagnet said: After i fitted the Depo ones to my car the headlightwashers still work as normal thanks for the info, incidentally how much are the original Nissan one's Genuine Nissan bi xenons are £730 ish each and strangely the earlier DE headlights are £930 ish each. Quote Link to comment Share on other sites More sharing options...
Masa Posted July 14, 2015 Share Posted July 14, 2015 I've got an 04 UK spec GT; if I do get them I will probably take them to a garage to get them properly fitted and adjusted; if the standard ones are that expensive new how much do they go for second hand?! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gort Posted July 14, 2015 Share Posted July 14, 2015 (edited) On 14/07/2015 at 15:58, StevoD said: just be aware might fail mot as 99% of aftermarket headlights even if sold by a UK supplier are for LHD you can buy either RHD or LHD from this seller Edited July 14, 2015 by gort 1 Quote Link to comment Share on other sites More sharing options...
gort Posted July 14, 2015 Share Posted July 14, 2015 c On 14/07/2015 at 16:06, ZEUS said: On 13/07/2015 at 18:14, gort said: On 13/07/2015 at 18:09, BulletMagnet said: After i fitted the Depo ones to my car the headlightwashers still work as normal thanks for the info, incidentally how much are the original Nissan one's Genuine Nissan bi xenons are £730 ish each and strangely the earlier DE headlights are £930 ish each. Can't believe the mind boggling price Nissan want for new headlights! Quote Link to comment Share on other sites More sharing options...
redzed8 Posted July 14, 2015 Share Posted July 14, 2015 (edited) On 14/07/2015 at 16:29, Masa said: I've got an 04 UK spec GT; if I do get them I will probably take them to a garage to get them properly fitted and adjusted; if the standard ones are that expensive new how much do they go for second hand?! Sent from my iPhone using Tapatalk I paid £330 for my 06+ (genuine) headlights including ballasts. Straight plug and play no issues. Sold my old xenons for 295 on ebay. So cost me 35 pounds really. Just need to keep your eye out as they dont hang around when they are for sale. Edited July 14, 2015 by redzed8 Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 14, 2015 Share Posted July 14, 2015 My US ones adjusted up well within tolerance of UK specs. Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 15, 2015 Share Posted July 15, 2015 On 14/07/2015 at 17:50, veilside z said: My US ones adjusted up well within tolerance of UK specs. But isn't the beam pattern the wrong way round? I guess so long as the highest part of the beam is within tolerances, it's fine, but I think there'll be a slight loss in throw distance. Quote Link to comment Share on other sites More sharing options...
gort Posted July 29, 2015 Share Posted July 29, 2015 On 14/07/2015 at 14:22, Masa said: So for clarification, replacing the OEM HID's with the sellers preinstalled option would solve the incompatibility, however they would not be legal as the auto levelling won't work...? Or does the preinstalled option have the 8 pin connector with the auto levelling? If no one can answer I shall ask the seller and post up responses for others Sent from my iPhone using Tapatalk did you get any response from the seller, the one's I were looking at come with a set of halogen bulbs I think?,so that would bypass the xenon ballasts Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 29, 2015 Share Posted July 29, 2015 Little loss in throw mate but still surprisingly good compared to oem. 1 Quote Link to comment Share on other sites More sharing options...
