parello9 Posted June 21, 2015 Share Posted June 21, 2015 Anyone got one of these or seen it? http://www.kleers.com/Kleers-Jetwash-1000 seems good for what it is but would prefer an honest review if anyone has it Good idea i think none the less Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted June 21, 2015 Share Posted June 21, 2015 Loving that idea! Quote Link to comment Share on other sites More sharing options...
sharkmatt Posted June 21, 2015 Share Posted June 21, 2015 That looks great! Price isn't bad at £99 either. The videos on facebook look pretty good, not as powerful as a true pressure washer but that's to be expected. Plenty powerful enough to wash a car though I think. Quote Link to comment Share on other sites More sharing options...
alexwitham Posted June 22, 2015 Share Posted June 22, 2015 That does look like a decent idea. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 22, 2015 Share Posted June 22, 2015 Between 2-9 bar compared to the bottom-of-the-market (cheaper) Nilfisk at 110 bar is a significant difference. That would struggle to clean a car much at all, considering that tap water pressure is typically around 1 bar. If you've got access to an electrical source, you're better off using a proper pressure washer that can draw from a bucket/water butt. If you've not got access to an electrical source, you're better off going somewhere that you can use a proper pressure washer. It's a good theory, but there's a reason these aren't very common. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 22, 2015 Share Posted June 22, 2015 I think the theory is to clean the car again at a car show - hence the portability - and as the car would have already been cleaned once, it wouldn't need such a high amount of power. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 22, 2015 Share Posted June 22, 2015 In that case, it'd be better than just using a QD but that just makes it an expensive alternative to using a rinseless wash. Not sure I see the point at that price to be honest, but each to their own. Quote Link to comment Share on other sites More sharing options...
Wendy Posted June 22, 2015 Share Posted June 22, 2015 I bought a Garden Sprays for £7.99 from Aldi - but for the pure use of using when at shows. Probably holds 5 litres of water. Of course there will hardly be any force compared to a powered Jet spray, but sufficient for a relatively clean car and just wanting to get it wet to remove dust, clean wheels etc or rinse off. 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted June 22, 2015 Share Posted June 22, 2015 Good idea. Quote Link to comment Share on other sites More sharing options...
Voodoo Vix Posted June 22, 2015 Share Posted June 22, 2015 We've got one of these, not great, but cheap as chips and handy for shows http://www.amazon.co.uk/Hozelock-Ltd-4140A0000-Porta-Shower/dp/B001ULCILM Quote Link to comment Share on other sites More sharing options...
sharkmatt Posted June 22, 2015 Share Posted June 22, 2015 I live in a 1st floor flat so whacking a hose and power cord out of the window, although an option, isn't a desirable one. I could go to my mums house and use their pressure washer but who wants to do that every time the car needs a clean. I do have a garden sprayer but it just doesn't move enough water volume to adequately rinse the car and there's no way to snow foam. This seems like a good mid ground. It's not perfect but I think it would do the job fine if the car was already cleaned and protected and you were just looking to maintain it every week. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 22, 2015 Share Posted June 22, 2015 You still wouldn't be able to snow foam with this - you'd be hard pushed to find a lance that fit it, for a start, and even harder pushed still to get it to produce enough pressure to foam anyway! Even if you could get the foam on, foaming is entirely pointless if you can't give it a proper, thorough rinse with a decent water source - the purpose of using a pressure washer is not for the volume of water, but the pressure itself will remove dirt than just using a hose (or this!) in the same way. It might be a bit more hassle but you really will be better off going to your mum's house. This simply doesn't offer anything useful that I can see. That's just my opinion though, waste your money as you see fit. Quote Link to comment Share on other sites More sharing options...
Wendy Posted June 22, 2015 Share Posted June 22, 2015 We've got one of these, not great, but cheap as chips and handy for shows http://www.amazon.co...r/dp/B001ULCILM So pretty much the same as mine except for the shower head and more expensive !! Quote Link to comment Share on other sites More sharing options...
sharkmatt Posted June 22, 2015 Share Posted June 22, 2015 You still wouldn't be able to snow foam with this - you'd be hard pushed to find a lance that fit it, for a start, and even harder pushed still to get it to produce enough pressure to foam anyway! Even if you could get the foam on, foaming is entirely pointless if you can't give it a proper, thorough rinse with a decent water source - the purpose of using a pressure washer is not for the volume of water, but the pressure itself will remove dirt than just using a hose (or this!) in the same way. It might be a bit more hassle but you really will be better off going to your mum's house. This simply doesn't offer anything useful that I can see. That's just my opinion though, waste your money as you see fit. All good points. Maybe I'll just annoy the neighbours and hang a hose out of my window I guess I need to get used to throwing money away now I'm planning on buying a Zed though Quote Link to comment Share on other sites More sharing options...
StevoD Posted June 23, 2015 Share Posted June 23, 2015 1 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 23, 2015 Share Posted June 23, 2015 I was going to say, stop spending money on crap like this Buuuuut that's pretty cool. That is pretty much ideal for people with no access to taps or at car shows, after you've driven in damp/wet conditions, you can just wash all the @*!# off, then finish up with the QD. Does it use a full tank for a car? Dibs at events to borrow it! Quote Link to comment Share on other sites More sharing options...
StevoD Posted June 23, 2015 Share Posted June 23, 2015 drain a tank in 10 mins of constant use Quote Link to comment Share on other sites More sharing options...
parello9 Posted June 23, 2015 Author Share Posted June 23, 2015 Yess need to get me one now if steve has one Quote Link to comment Share on other sites More sharing options...
ZEUS Posted June 23, 2015 Share Posted June 23, 2015 Looks pretty good actually Steve Quote Link to comment Share on other sites More sharing options...
Stutopia Posted June 23, 2015 Share Posted June 23, 2015 I'm confused, apart from eliminating the manual pumping, what does it bring to the party over a hand pump sprayer? If, all you're doing is shifting dust at a show, you can spray with one hand and microfibre with the other http://www.autobritedirect.co.uk/index.php/checkout/cart/ Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 23, 2015 Share Posted June 23, 2015 I was thinking the same thing, but about this attached to a bottle of water; http:// http://www.polishedbliss.co.uk/acatalog/atomiza-standard-spray-head-cat25.html Quote Link to comment Share on other sites More sharing options...
