joncessna Posted June 21, 2015 Share Posted June 21, 2015 Following my MOT renewal , it appears my main Odometer stopped recording for all but 60 miles since last MOT ! I never look at that one and it's all working now, only noticed it because I read the MOT history list to see what last years total was . Speedo is fine and no other symptoms of any kind . I only do between 3 and 6 thousand a year in the Z. Any bright ideas anyone ? Does the ECU record mileage and will it show on a scanner ? Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 21, 2015 Share Posted June 21, 2015 (edited) Welcome along My first question would be are you 100% sure that last year's MOT reading was correct? I'd suspect that a fat finger typing that in is much more likely than the main odometer not working correctly. Easy to test too, just go for a drive and see if it moves. Edited June 21, 2015 by Ekona Quote Link to comment Share on other sites More sharing options...
joncessna Posted June 21, 2015 Author Share Posted June 21, 2015 Yes to checking both of those ! I keep petrol receipts and they match the 2013-14 mileage as near as poss . It's the 2014-15 that's missing . Havn't done a total fuel check yet but it's quite low , prob around 3 thousand . I assume the main recording is stored on the speedo , but does the ECU also keep a separate record.? As I say , it's working fine now and since the MOT , just the total for a year of 60 miles ! Unfortunately , I never look at or record the total anywhere else . My Twin Turbo had a speedo prob but that showed up on the speedo dial too of course . Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 21, 2015 Share Posted June 21, 2015 In that case, I have no idea! Pretty sure the mileage is kept on the ECU as well on the 350, so swapping clusters wouldn't help. If it's working now then I'm not sure what can be done, the only thing you can do is keep a note of the mileages and explain the issue should anyone ask when you come to sell it. Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 21, 2015 Share Posted June 21, 2015 In that case, I have no idea! Pretty sure the mileage is kept on the ECU as well on the 350, so swapping clusters wouldn't help. If it's working now then I'm not sure what can be done, the only thing you can do is keep a note of the mileages and explain the issue should anyone ask when you come to sell it. Mileage Is kept on the clusters Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 21, 2015 Share Posted June 21, 2015 Ah, I thought it wasn't, I must be confusing cars Not that that will help mind, it's out regardless so really nothing that can be done unless you find a cluster that has more or less the same miles on and swap. Quote Link to comment Share on other sites More sharing options...
joncessna Posted June 21, 2015 Author Share Posted June 21, 2015 Thanks anyway , I'll get the scanner plugged in and see what it says ; get back with info when I know more . Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 21, 2015 Share Posted June 21, 2015 You can get your current cluster altered if your concerned, ecu wont give you mileage reading Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 21, 2015 Share Posted June 21, 2015 Welcome to the forum. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 21, 2015 Share Posted June 21, 2015 Welcome aboard. Quote Link to comment Share on other sites More sharing options...
Z370Z Posted June 21, 2015 Share Posted June 21, 2015 Quote Link to comment Share on other sites More sharing options...
Steel Lynx Posted June 22, 2015 Share Posted June 22, 2015 Welcome to the forum Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted June 22, 2015 Share Posted June 22, 2015 Quote Link to comment Share on other sites More sharing options...
Keyser Posted June 22, 2015 Share Posted June 22, 2015 along Strange problem you have there - no idea how you would fix it other than getting the reading reset by a specialist company. Quote Link to comment Share on other sites More sharing options...
veilside z Posted June 22, 2015 Share Posted June 22, 2015 Hello and welcome buddy. Hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
