chippychip123 Posted June 21, 2015 Share Posted June 21, 2015 Hi, I'm after a bit of advice from anyone that's already replaced these bushes! I'm in the middle of replacing the last of my front bushes with whiteline ones and I'm unsure about the front lower control arm ( not the banana arm ) the new bush runs the full length of the centre pin unlike the OEM ones which is fine but where the bush sits in the crossmember there are two small lugs/welds each side that help locate the OEM pin. My question is do you grind these off flush so that they don't chew the new bush up or just wedge the bushes in? Thanks Tom Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted June 21, 2015 Share Posted June 21, 2015 Check out this dude. Pretty sure I see him grinding off something in the video Quote Link to comment Share on other sites More sharing options...
chippychip123 Posted June 21, 2015 Author Share Posted June 21, 2015 Cheers mate, yea he's grinding off the little tabs on the std shocks for the same reason! I'm on coilovers though so no need. I've done a bit of research and some say do it and others say don't bother, think I'm going to just grind them off Quote Link to comment Share on other sites More sharing options...
