Can anyone help (spacer question)
Joeycuz
Hi, just went to fit some Eibach spacers and can across a problem.
Fronts are 20mm
Rear 25mm
The two sets are completely different. The rears simply go over the original studs, but the fronts came with a set of studs in the box.
How do I fit the fronts?!
Sorry for the poor description so here's a pic.
Currently sat in my car on the drive half way through fitting in the pis$ing rain. :)
Thanks for that. Is this normal then for 20mm spacers as it would of been a lot easier if it had the same design as the 25mm. I done the rears in ten mins, now the fronts look like a pain in the ass.
There are two different fitments, you have one of each.
Both are normal and work :thumbs:
