Fuppet Posted June 14, 2015 Share Posted June 14, 2015 As above, i've got an issue with water underneath/back of the drivers seat. Since the warmer weather i haven't had the heater on and the water issue has been solved. Is it possible the heater generates water that could leak into the cabin? For reference, it has still rained recently, so it isn't due to the weather being dry. Quote Link to comment Share on other sites More sharing options...
Will370z Posted June 14, 2015 Share Posted June 14, 2015 i4n had exactly the same issue last year I recall. May be worth sending him a pm to see what he did to fix it Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 14, 2015 Share Posted June 14, 2015 Can't see how the heater would 'leak' to the rear of the seat area and anyway you would see coolant and rad water level drop. Maybe a hole of some description allowing water in from underneath or from a real hatch or door seal? Can't think it would be anything else. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 14, 2015 Share Posted June 14, 2015 i4n had exactly the same issue last year I recall. May be worth sending him a pm to see what he did to fix it Yep he did, ...here's the thread Op fyi: http://www.350z-uk.com/topic/86683-water-in-my-zed-solved/ Hopefully you'll get it sorted soon just like he did. 1 Quote Link to comment Share on other sites More sharing options...
