ziglo Posted June 13, 2015 Share Posted June 13, 2015 I have just purchased a a 370z roadster and after having the roof up and down a couple of times the roof warning light is staying illuminated. Would anyone know if there's anything I can do or does in need to be hooked up to the laptop to determine the fault. The roof operates as normal and seals properly like it should so nothing obvious Any help ? Thanks Ziglo Quote Link to comment Share on other sites More sharing options...
Will370z Posted June 13, 2015 Share Posted June 13, 2015 Welcome. It could be any number of things. I would give sly at kaizer motors a call, he's a trader on here. Quote Link to comment Share on other sites More sharing options...
ziglo Posted June 13, 2015 Author Share Posted June 13, 2015 Thanks Will 370z, I'm thinking its a sensor but guess I will have it booked in and rigged up the diagnostics, cheers Ziglo Quote Link to comment Share on other sites More sharing options...
Mrzapie Posted July 22, 2018 Share Posted July 22, 2018 Hi, As a reference point we had the same warning light problem. Failed connector for the heated rear window. 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 22, 2018 Share Posted July 22, 2018 1 hour ago, Mrzapie said: Hi, As a reference point we had the same warning light problem. Failed connector for the heated rear window. 2 Good shout: Quote Link to comment Share on other sites More sharing options...
