Building false floor
jayrishi
I did mine recently, Its a bit of a pain as the boot has a lot of bolts which stick up about an inch so make it hard to get it perfectly flat.
First clear out all the wheel well padding and stuff
Then I would lay a good layer of dynamat down. This will help smooth out some of the bumps and stuff. I also cut the spare wheel bracket out with my dremmel
Get some 1 inch foam block to support the base and deal with the raised bolts and build your false floor
