Carbotech pads enlighten me
nissanman312
  On 09/06/2015 at 18:36, nissanman312 said:
I take it you rate them Alex
I'm guessing a fast road setup is enough for me I don't track 8 or 10 compound
If your car is stock then 6 will do for spirited driving or if you push on then perhaps 8.
Both are rotor friendly.
I use 10 rears and 12 front.
Supercharged 460bhp I like to push on
So would you recommend your setup then
  On 10/06/2015 at 07:38, ZMANALEX said:
8 should be fine for your application.
Alex have you used PF compound eg 01 or pagid rs 15 or 29? If yes how does it compared to the car carbotechs 10/12?
Edited by GT4 Zed
I have used PF01 and Pagid RS29 and I prefer Carbotech.
Each to there own thou.
Try them, :thumbs: however 12 may be overkill for your application.
Alex :)
  • 10 months later...
  On 10/06/2015 at 15:06, nissanman312 said:
I keep getting told ferodo 2500 are better no noise and less dust but I've also herd these are loads better
No comparison to the DS2500, Carbo's are far better. Ive got XP10's on the front of my 135i and Ive been impressed, only bad part was that I managed to set fire to the passenger side cailper while bedding in so its a bit noisy when giving full brake death.
Prefer them to RS29 but would probably still take Carbon Lorraine RC05+ given the choice :)
