Gargravarr Posted June 9, 2015 Share Posted June 9, 2015 Hello, One of my brake lights has failed, and I bought a set off Autobulbs to replace them. Didn't check the forum first, and found out autobulbs think that the car uses a bayonet, but it's a wedge 7443 in my car... I figured now might be a fun one to try out LED bulbs in the car. I've searched around the forum a bit, but I can't find anyone referencing a set of LED bulbs with the resistor inside for the running lights? Autobulbs only have one that is non canbus (so I assume it's not got a resistor?). I'd prefer not to be wedging resistors etc into bulbs that are used for brake lights if I can. http://www.autobulbsdirect.co.uk/ABD-7443HP-21/5W-54-LED-WEDGE-WHITE-and-RED.html I can't seem to find any direct part recommendations on the forum, and there are a few comments that the bulbs are 7443 not 580, and that there is a difference. I know CS2000 did a pack a while ago, but it seems like he's no longer doing them. Has anyone changed out their OEM bulbs to LED and not had the brake light fault light? and if so, what part did you use? I've got a 55 plate coupe. Thank you! Quote Link to comment Share on other sites More sharing options...
zebedy Posted June 9, 2015 Share Posted June 9, 2015 Go and down load the app GEEK. Its great for obscure stuff like bulbs etc. I took a look and found 6 straight away but cant cut n paste because its held within the app. Geek sell everything. Cheap stuff too. All from oversea and delivery takes a few weeks. Ive used this side and have never been dissapointed. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 9, 2015 Share Posted June 9, 2015 I swapped to 06+ OEM LED light clusters Quote Link to comment Share on other sites More sharing options...
Gargravarr Posted June 9, 2015 Author Share Posted June 9, 2015 BulletMagnet, how hard was the LED cluster swap? is it a direct bulb replacement, or does it involve cutting up the housing? Also, does anyone know where to get straight OEM filament bulbs for the rear? Autobulbs don't seem to have 7443 non-LED bulbs, and I can't find many that look like proper brands. Are they really that niche? Quote Link to comment Share on other sites More sharing options...
zebedy Posted June 9, 2015 Share Posted June 9, 2015 You swap yoyr 05 lights to 06 lights (led) takes ten mins. Quote Link to comment Share on other sites More sharing options...
Gargravarr Posted June 9, 2015 Author Share Posted June 9, 2015 Nice one, so, as a follow up question, what are the specs for the 06 LED lights? and where do I get one? sorry about all these questions, I can't seem to find any guides on the site! Quote Link to comment Share on other sites More sharing options...
Gargravarr Posted June 9, 2015 Author Share Posted June 9, 2015 Wait, just realised you're talking about the whole cluster, mirrors and lenses etc. Those look to be about 200+ quid, which is a bit more than my budget! All I want to do is switch out the bulbs with some LEDs, surely this isn't too rare of a request? Quote Link to comment Share on other sites More sharing options...
ZEUS Posted June 9, 2015 Share Posted June 9, 2015 For the facelift LED light upgrade you swap the whole rear cluster not just the bulbs and you can buy new genuine Nissan ones from Clarke motorsport for around £285. I have no idea about just changing bulbs for LED ones though. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 9, 2015 Share Posted June 9, 2015 Yup, swapped the whole thing Worthwhile tho, looks best, just save up a bit and get some. Quote Link to comment Share on other sites More sharing options...
Gargravarr Posted June 11, 2015 Author Share Posted June 11, 2015 Cheers for the info! I don't think I can justify the expense for changing out the lights clusters, but I'll see if eBay can provide some decent LED bulbs. Thanks everyone for your help! Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted June 11, 2015 Share Posted June 11, 2015 You know you want to...I swapped mine over the other day Quote Link to comment Share on other sites More sharing options...
Gargravarr Posted June 12, 2015 Author Share Posted June 12, 2015 Haha, I would love to, but I can't justify £200 on a mod that doesn't change the performance! I've asked a seller on eBay about a LED bulb that should work. I'll let you know about it if it works! Sent from my D5503 using Tapatalk Quote Link to comment Share on other sites More sharing options...
