Jabbah Posted June 8, 2015 Share Posted June 8, 2015 Front washer jets stopped working and seems to be the wiring. No voltage across plug when activating jets, pump works when connected directly to a battery, rear pump connected to front plumbing works. As I have no rear wiper washer jet I have it connected up so activating the rear jet sprays on to the front. Any ideas how to track this fault down? MOT is up for renewal soon and not sure if this setup will pass. I want to get it back to having auto wipe after spray anyway. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 8, 2015 Share Posted June 8, 2015 Fuse? Quote Link to comment Share on other sites More sharing options...
Jabbah Posted June 8, 2015 Author Share Posted June 8, 2015 I tried swapping a load of fuses around but TBH I couldn't find anywhere that definitely said which the fuse for the front washers was. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 8, 2015 Share Posted June 8, 2015 http://www.350z-uk.com/topic/71948-where-is-the-washer-jet-fuses/ Quote Link to comment Share on other sites More sharing options...
Jabbah Posted June 8, 2015 Author Share Posted June 8, 2015 (edited) I'm pretty sure I checked that one, but it's been a few months since so will check and make sure. I may have just checked all the ones in the box in front of the battery. Thanks. Is there a separate fuse for the front and back jets? Edited June 8, 2015 by Jabbah Quote Link to comment Share on other sites More sharing options...
