jimboy2 Posted June 8, 2015 Share Posted June 8, 2015 Having my HFC fitted to my HR on Friday. Really don't want the eml light in all the time, I hear O2 spacers cure this. Should I just fit them straight away? Next question. Price and supplier? Cheers Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted June 8, 2015 Author Share Posted June 8, 2015 Massive search fail. Berks have them already right? Quote Link to comment Share on other sites More sharing options...
Commander Posted June 8, 2015 Share Posted June 8, 2015 Not sure about Berks, but my CNTs certainly have them already, and I don't have any problems. Quote Link to comment Share on other sites More sharing options...
westyno9 Posted June 8, 2015 Share Posted June 8, 2015 I don't have any problems with my berks. Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted June 8, 2015 Share Posted June 8, 2015 (edited) Depending on how far you go with the flow, Spacers will not stop The EML coming on after installing HFCs or Decats. if it does, then it's witch craft! it'll come on at approximately 1000 miles after the install. Edited June 8, 2015 by Rock_Steady Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 8, 2015 Share Posted June 8, 2015 Uprev is the only way to remove I thought . Well it did on my one Alan Quote Link to comment Share on other sites More sharing options...
Mudman Posted June 8, 2015 Share Posted June 8, 2015 Mine have been on a month and were fine before uprev Quote Link to comment Share on other sites More sharing options...
Fluke Posted June 8, 2015 Share Posted June 8, 2015 I have had the uprev with decats and I had no CEL, but now with my Berk HFC's fitted I get a CEL. Quote Link to comment Share on other sites More sharing options...
CJRamze Posted June 11, 2015 Share Posted June 11, 2015 Sorry to piggyback onto this. I've picked up my car yesterday from the guy whom fitted my exhaust. As soon as I turned the car on the EML light comes on. I'm using CNT / ERZ Cats, do you think an O2 spacer would work with these? If the EML light is on will it run lean etc? Can it cause any damage? Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted June 24, 2015 Share Posted June 24, 2015 (edited) If you have a plenum spacer and HFCs and an aftermarket exhaust system with a cold air feed, then yes, it'll run leaner, but the ECU reigns it in a bit which is what brings up the EML. Will it do any damage? No, probably not, even though some members are like old ladies who panic about it and believe it does. Having said that, no zed is the same. No idea if the spacer will work on those de-cats, all i can tell you is, spacers didn't work for my HFCs. Edited June 24, 2015 by Rock_Steady Quote Link to comment Share on other sites More sharing options...
