PS tank help please
JoKeR
Sweet! Thanks man :thumbs:
While its fresh in your memory - what diameter hoses are required? Have you changed all of it? Or left hard pipes in?
I can probably Google it all, but I'm too lazy ;):lol:
Lol no worries mate. The stock sizes are about 9mm and 14mm. That's rough because they vary depending on which side I measure I assume due to them stretching slightly over the years.
The hose I bought was a 13mm inside diameter straight silicone pipe. Measured the rough length and cut to size.
13mm fits perfect on the pump to tank side. The connection on my tank is also 13mm so that was all good.
The other side of the tank was 13mm so I need to use 13mm there too. However the pipe it would go on to from that side of the tank was the 9mm one.
This is where I thought I had a problem but wasn't that at all.
All I did was buy a 13mm to 9mm reducer, cut the OEM pipe about 3" long, fit the reducer in between the 13mm hose and the 9mm hose then connect the 13mm side to the tank and the 9mm side to the end pipe and it was all good.
Hope that helps and isn't too confusing mate lol
That's what she 'Zed' :-/
