Pinoy Z Posted June 2, 2015 Share Posted June 2, 2015 Hi does anyone know the exact size of the front brembo brake pads.I bought some but they don't fit they were too big on the width,same with the apec ones.All the car garages I've been to seem not to know the size.I even went to the Nissan dealer and still had no luck Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted June 2, 2015 Share Posted June 2, 2015 http://www.ebay.co.uk/itm/NISSAN-350Z-BREMBO-EBC-Yellow-Stuff-FRONT-Brake-Pads-Yellowstuff-1128-/291439430606?pt=LH_DefaultDomain_3&fits=Model%3A350+Z&hash=item43db24cbce Or from Ferodo: http://www.camskill.co.uk/products.php?mode=search Technical specifications: Braking System: BREMBO Axle: Front Axle Width: 119.8mm Height: 73.6mm Thickness: 15.0mm Surface Friction Height: 55.6mm 1 Quote Link to comment Share on other sites More sharing options...
firemansim Posted June 2, 2015 Share Posted June 2, 2015 When I changed mine I had to grind some of the edges away. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted June 2, 2015 Share Posted June 2, 2015 Same here. Just order them from any of our traders on here if you aren't sure. They should just drop in, no force required. 1 Quote Link to comment Share on other sites More sharing options...
Pinoy Z Posted June 13, 2015 Author Share Posted June 13, 2015 Thanks for the info will look into it Quote Link to comment Share on other sites More sharing options...
johnny cobra Posted June 13, 2015 Share Posted June 13, 2015 Had to file mine too Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted June 13, 2015 Share Posted June 13, 2015 (edited) You'll probably find that the calliper has corroded slightly behind the stainless plates that sit at each end of the pad on the calliper pushing them out causing the pad to be a tight fit. I found this especially on the rear pad and had to grind some off to get them in, not too much though as they will move and knock. Edited June 13, 2015 by SHEZZA 1 Quote Link to comment Share on other sites More sharing options...
Pinoy Z Posted June 13, 2015 Author Share Posted June 13, 2015 Yeah I had my brembo pads filed down by a machanc but they squeak every time I come to a stop.I had a look and at the pads myself as the squeaking was driving me crazy.He filed them down abit to much.I have to get another new pair now. Quote Link to comment Share on other sites More sharing options...
