Suspension issue
chrisday1990
Hey fellow Zers
Over speed bumps at low speeds I have a clunk clunk from front LHS, a few garages seem unsure so I was wondering is there any definitive way to find the knock because it's expensive to get it worong, I have seen MOT centres with the rumble jacks maybe these? And if I leave it to get worse could this make it easier for a garage to spot?
Edited by chrisday1990
Chris,
More than likely it will be the compression rod ball joint (banana arm) so this would be a very good place to start, however difficult to find play with a pry bar.
Plenty in stock if required, just drop me a PM if I can help further.
Alex. :)
I had the same problem but drivers side.
This is what i found when i took the dust cover off my old banana arm ball joint .
Sounded just like this when it was on the car too.
Edited by redzed8
