import Brakes??
maseon
just getting my 03 import z MOT done and it failed on the front brake pads and disks
they are saying they have to order in the import ones as they are different (this sounds like itl cost a arm and leg from kwik fit)
i was wondering if anyone knows of brake pad/disk sets that will be fine on a import??
Hi and welcome. Yes they will have to order the non brembo discs and pads in ! Though I'd guess they'd have to order the brembo discs and pads in aswell as I can't see kwik fit stocking either so there having a laugh there. Non brembo discs and pads are the cheaper of the two so I wouldn't worry there.
right/
just got it back from MOT garage and now im confused because the calipers are brembo? not sure if its been change before i got it or if any jap versions have brembo labelled as standard
thank all btw for the advise
^^ As above ~ those are Brembos.
These below are none Brembos...
If you're lucky someone has upgraded your import Zed to the Brembo braking set up, ...if you're unlucky someone has just stuck a Brembo sticker on the import calipers. :dry::lol:
they look the same
heres a pic
You have Brembo brakes. B):D
Here are some options available to you from Horsham Developments: http://www.h-dev.co.uk/index.php?cPath=78_169_293_463_465_1414
And some more from the Cougar Store: http://cougarstore.co.uk/index.php?main_page=index&cPath=1_7_3&zenid=bcaa60565806895c2c0f2d2ff1b32aee
http://cougarstore.co.uk/index.php?main_page=index&cPath=1_7_6&zenid=bcaa60565806895c2c0f2d2ff1b32aee
Lot's of traders on here though that can help you out depending on your budget & what you want.
You looking to upgrade from the factory set up or just do it as cheap as possible & not bothered about the make etc?
