jumping350 Posted May 28, 2015 Share Posted May 28, 2015 (edited) I have got the car ready to install my blox plenum spacer but a bit unsure of the bolts and where they go and if I have enough etc Read a few guides (motordyne) but they don't go into to much detail on the bolts and some get reused but don't know which ones! As loads of people have done this, would be good if someone knows where what goes Here is what I have and below what I know: 1, 6 x spacers that go underneath plenum and bolt goes through it 2. Many washers - I presume every bolt needs a washer for it 3.10 x short bolts - I believe these are for the outer bolts around the plenum 4. 4 x long bolts I thought these were for the middle of plenum (do I not need 6? do I reuse any?) 5. 3 x slighter shorter than long bolts - no idea 6. 2 x halford bolts - no idea Any help appreciated and any info on which bolts go where and what to reuse (where do they go in second picture) Edited May 28, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
Wasso Posted May 28, 2015 Share Posted May 28, 2015 I'll call you Quote Link to comment Share on other sites More sharing options...
