daveallen1999 Posted May 25, 2015 Share Posted May 25, 2015 Hi, I have just brought some Eibach Spacers for my 350Z, 20mm front and 25mm for rear tyres. I plan to match them up with my standard ray alloys with Toyo R888s. The question I need to ask is there any danger in using the spacers. Are the spacers strong enough to put up with the forces the wheels will encounter on a track day ? Could I have some advice on this please. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 25, 2015 Share Posted May 25, 2015 (edited) Genuine Eibach spacers will be fine providing they are fitted properly, however they do place extra load on other components and some say that they effect handling. I run Eibach 20/25 on my TT 350 but not on the R35. Both cars used on track. Hope this input helps. Alex. Edited May 25, 2015 by ZMANALEX 1 Quote Link to comment Share on other sites More sharing options...
alexwitham Posted May 25, 2015 Share Posted May 25, 2015 Alex, do you think handling is effected fitting the spacers? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 25, 2015 Share Posted May 25, 2015 Alex, do you think handling is effected fitting the spacers? I personally have no handling issues with 20/25 spacers running wets, intermediates or slicks. Alex. Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted May 25, 2015 Share Posted May 25, 2015 +1 with Alex. Good quality spacers eg eibach fitted properly are safe but I would go past 25mm and it should improve your handling(lateral stability) by increasing your track width in general but you need to know what you are doing if you want to tune the car with spacers. E.g I was suffering bad under steer and lack of front end grip in the wet but increasing my front track with spacer was the only thing that made the biggest difference after playing with softer setting on damper and ARB and geometry. Quote Link to comment Share on other sites More sharing options...
daveallen1999 Posted May 25, 2015 Author Share Posted May 25, 2015 Genuine Eibach spacers will be fine providing they are fitted properly, however they do place extra load on other components and some say that they effect handling. I run Eibach 20/25 on my TT 350 but not on the R35. Both cars used on track. Hope this input helps. Alex. Thank you, Alex. Quote Link to comment Share on other sites More sharing options...
