Roscoe Posted May 21, 2015 Share Posted May 21, 2015 Zed won't unlock remotely all of sudden on both keys. Unlocks by hand then alarm goes off and starts fine... Any help appreciated. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted May 21, 2015 Share Posted May 21, 2015 Key batteries dead ? 1 Quote Link to comment Share on other sites More sharing options...
raysw20 Posted May 21, 2015 Share Posted May 21, 2015 Mine did that couple of weeks ago. both batteries were dead Quote Link to comment Share on other sites More sharing options...
Roscoe Posted May 21, 2015 Author Share Posted May 21, 2015 Well I just started it while the alarm was going off and got out again and now both keys work again... Don't think it's a battery issue. Quote Link to comment Share on other sites More sharing options...
coldel Posted May 21, 2015 Share Posted May 21, 2015 Bizarre that both batteries died at the same time? Would a reset of the car make a difference? Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted May 21, 2015 Share Posted May 21, 2015 I'd just replace the batteries anyway, they don't last forever and it eliminates a simple possible cause. Quote Link to comment Share on other sites More sharing options...
Roscoe Posted May 21, 2015 Author Share Posted May 21, 2015 Yeah I'm sure it's not the battery's as they both work fine again now. One thing I did notice once the car had started and alarm had stopped, around 30 seconds later the hazards lights flashed while I was driving. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted May 21, 2015 Share Posted May 21, 2015 Sure you've got a Z not an Alfa ? 2 Quote Link to comment Share on other sites More sharing options...
Grundy Posted May 21, 2015 Share Posted May 21, 2015 Some criminal was using a jammer at the same time you were pressing your unlock key, to gain the codes to unlock you car tonight while you're sleeping Quote Link to comment Share on other sites More sharing options...
Roscoe Posted May 21, 2015 Author Share Posted May 21, 2015 I hope not ha!! Well all is well at the moment, I'm hoping the NATS has just reset itself. I will change the battery in the keys anyway just to rule that out if it happens again. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted May 21, 2015 Share Posted May 21, 2015 Alarm systems do very worrying things when the car battery is on it's way out. Check the battery is healthy. You can also reset everything by removing the car battery for a while. 30 minutes should be enough. Quote Link to comment Share on other sites More sharing options...
