Festoon builb blows fuse
mrkieran23
So as the above says, put some led festoon bulbs in and I heard a pop and the light went, while searching for the fuse box I caught the indicator which also didn't work.... I got worried.
Found the fuse box and there was 10amp fuse gone, replaced it with a spare and indicators now work but the dome lights only work when pressed, not auto when the door opens.
Anybody ideas?
I'd check the door switch little black rubber thing in the door shut, may have sparked when the fuse blew and now not making a good connection - just an idea :shrug:
Oops! Personally if it were me, I'd just leave it so long as everything else is working. But, I was under the impression that if it as the BCM it would be a bigger issue than the dome lights not operating with the door. Hopefully something simpler.
