*** TORQEN *** 350z DE and HR CLUTCH KITS - All you need is here!
Adrian@TORQEN
Guys,
Recently we have had a number of orders for new clutch kits because of original Nissan clutch failures. This is hardly surprising given the age and mileage of the 350z now. Allied to this we have received numerous enquiries from folk trying to establish which is the best solution for them.
To enable you to take the guess work out of your clutch/package selection we have put together an easy to understand staged clutch upgrade range of products and allied that to other clutch/gearbox related parts as often it makes sense to carry out additional work/upgrades while the gearbox is off the car.
It is important to remember when replacing your worn out clutch that other associated clutch system parts may also be worthy of upgrade. Failures in the Master and Slave Cylinders are not uncommon and have been documented well on this forum. This is particularly relevant if you are upgrading to a clutch with higher-pressure plate/spring ratings than the standard clutch. Replacement of these items with either OEM or upgraded products is a serious consideration as there is nothing worse than having to carry out secondary work with all the inconvenience and additional costs associated with subsequent unreplaced part failure, so please check out all our prices when making your choice.
We are able to supply JWT, EXEDY, SPEC, SOUTH BEND, COMPETITION CLUTCH, OS GIKEN, CLUTCH MASTERS and many other brands, but most importantly, price these competitively.
A. CLUTCHES
Stage 1
Torque capability > 350 lb/ft
Upgrade Organic clutch and Dual Mass Flywheel or Single Mass Flywheel.
Upgraded organic plate with more torque handling capacity, but similar OEM comfort if paired with Dual Mass Flywheel. The Single Mass Flywheel will be sportier with better engine responsiveness, but does chatter / rattle a bit more on idle and low revs, under 2000rpm.
Products - DE - 2003-2006
1. 350z DE SPEC Stage 1 Clutch Kit
Torque Capacity: 385 ft/lbs
2. 350z DE Clutch Masters FX100 Clutch Kit
Steel Back Heavy Duty Street System, 70% over stock holding capacity
3. 350z DE South Bend Clutch Kit HD Series Stage 1
Torque Rating: 350ft/lbs
4. 350z DE JWT Heavy Duty Clutch
1200KG clamping force, 570+ HP
Products - HR - 2007-2008
1. 350z HR Clutch Masters FX100 Clutch Kit
2. 350z HR Competition Clutch Stage 1 - Gravity Series 2400 Clutch Kit
40-50% of torque capacity and maintains stock pedal feel, not for FI such as turbo, supercharger, or NOS systems, TOB not included
3. 350z HR SPEC Stage 2 Clutch Kit
4. 350z HR South Bend Clutch Kit - Stage 1
5. 350z HR JWT Heavy Duty Clutch
Stage 2
Torque capability > 400 lb/ft
Organic or metallic clutch plate that usually comes with heavy duty(HD) pressure plate, recommended with Single Mass Flywheel.
For those with NA power and like the car to perform on fast road or track with just a 20-30% increase in pedal effort due to increased clamping loads. This is where the best sellers reside. We are fond of the JWT combo package, especially as it can hold 500 lb/ft! Huge value for money!
1. 350z DE SPEC Stage 2 Clutch Kit
Torque Capacity: 439 ft/lb
2. 350z DE Competition Clutch Stage 2 - Street Series 2100 Clutch Kit
80% increase in torque capacity
3. 350z DE Clutch Masters FX200 Clutch Kit
Kevlar Steel Back System, 70% over stock holding capacity
4. 350z DE South Bend Clutch Kit - Stage 2 - DAILY
Torque Rating: 500 ft/lb
5. 350z DE South Bend Clutch Kit - Stage 2 - ENDURANCE
6. 350z DE South Bend Clutch Kit - Stage 2 - DRAG
1. 350z HR Clutch Masters FX200 Clutch Kit
Kevlar Steel Back System, 70% over stock holding capacity, life expectancy is increased 2-3 times.
2. 350z HR Competition Clutch Stage 2 Steelback Brass Plus Clutch Kit
80% increase in torque capacity and properly suited for aggressive street use and moderate track use
Torque Capacity: 439 ft/lbs
4. 350z HR SPEC Stage 2+ Clutch Kit
5. 350z HR South Bend Clutch Kit - Stage 2 - DAILY
Torque Rating: 380ft/lbs
6. 350z HR South Bend Clutch Kit - Stage 2 - DRAG
7. 350z HR South Bend Clutch Kit - Stage 2 - ENDUR
Stage 3
Torque capability > 500 lb/ft
Ceramic or metallic clutch plate, recommended with Single Mass Flywheel.
If you are Supercharged or Turboed, then this is the minimum you would want to consider. Yes, your OEM clutch will work fine for a while, but we bet it will not last unless you drive like Miss Daisy or the car is a garage queen. This stage will also work for serious NA cars / drivers.
1. 350z DE SPEC Stage 3 Clutch Kit
Torque Capacity: 525 lb/ft
2. 350z DE SPEC Stage 3+ Clutch Kit
Torque Capacity: 610 lb/ft
3. 350z DE Clutch Masters FX300 Clutch Kit
Segmented Kevlar Steel Back System, 110% over stock holding capacity.
4. 350z DE South Bend Clutch Kit - Stage 3 - DAILY
Torque Rating: 715 ft/lbs
5. 350z DE South Bend Clutch Kit - Stage 3 - ENDURANCE
6. 350z DE South Bend Clutch Kit - Stage 3 - DRAG
Torque Rating: 715ft/lbs
1. 350z HR Clutch Masters FX300 Clutch Kit
2. 350z HR SPEC Stage 3 Clutch Kit
Torque Capacity: 525 ft/lbs
3. 350z HR SPEC Stage 3+ Clutch Kit
4. 350z HR Competition Clutch Stage 3 Segmented Ceramic Clutch Kit
150% increase in torque capacity
5. 350z HR Clutch Masters FX350 Clutch Kit
Higher holding capacity than a segmented Kevlar lining without compromising the street friendly characteristic
6. 350z HR South Bend Clutch Kit - Stage 3 - DAILY
Torque Rating: 575 ft /lbs
7. 350z HR South Bend Clutch Kit - Stage 3 - DRAG
8. 350z HR South Bend Clutch Kit - Stage 3 - ENDUR
Torque Rating: 575 ft/lbs
Stage 4
Torque capability 700 lb/ft
Twin plate non organic disc and integrated flywheel (FW).
This is now getting serious! While there are big brands like OS Giken, Carbonetic etc, we feel SPEC has got this covered with the big value kits that are not short on performance. There are 3 flavours: P-trim, SS-trim and ST-trim), but they all will handle between 700 to 1500 lb/ft of torque!
1. 350z DE Clutch Masters FX400 Clutch Kit
Ceramic System, 170% over stock holding capacity Ultra Heavy Duty Street and/or Racing.
2. 350z DE Competition Clutch Stage 4 - Strip Series 1620 Clutch Kit
250% increase in torque capacity
3. 350z DE South Bend Clutch Kit - Stage 4 - EXTREME
Torque Rating: 800+ ft/lb
1. 350z HR Clutch Masters FX400 Clutch Kit 4 or 6 puck
Ceramic System, 170% over stock holding capacity Ultra Heavy Duty Street and Racing
2. 350z HR Competition Clutch Stage 4 - 6 Pad Ceramic Clutch Kit
3. 350z HR SPEC Stage 4 Clutch Kit
4. 350z HR South Bend Clutch Kit - Stage 4
Torque Rating: 800+ ft/lbs
Note:
All stages, depending on brand, will come with brass pilot bearing, clutch alignment tool and a Throw-out Release Bearing (TOB). You will have to specify if you want a SMF or DMF and which brand. We can recommend for you amongst our extensive list of brands one to suit your needs, comfort, sport of hardcore performance.
On some brands like SOUTH BEND you can opt for a small fee for the quiet disk option, which reduces significantly the transmission rattle if you have gone with the SMF.
It is also important to know that these packages are no rigid and we will be able to advise, depending on your budget, to still get you the performance you require: eg you may want a clutch that can hold +700 lb/ft, but rather than go for the Stage 5 Twin setup, we can recommend a Single clutch disc setup that can hold that torque and at a lower cost.
B. FLYWHEELS
1. 350z DE Clutch Masters Flywheel
Weight: 19lbs
2-Piece Billet Aluminum Flywheel
2. 350z DE Clutch Masters Flywheel
Weight: 15lbs
3. 350z DE Competition Clutch Forged Ultra Lightweight Steel Flywheel
Weight: 13.89lbs
4. 350z DE Fidanza Flywheel - Aluminum
Weight: 14.45lbs
Fidanza Aluminum Flywheel
5. 350z DE South Bend Clutch Flywheel
1. 350Z HR Clutch Masters Aluminum Flywheel
FW Weight: 13lbs
2. 350Z HR Clutch Masters Steel Flywheel
FW Weight: 19lbs
3. 350Z HR Competition Clutch Steel Flywheel
FW Weight: 17.4lbs
4. 350z HR Fidanza Aluminum Flywheel
Weight: 15lbs
5. 350z HR Spec Aluminum Flywheel
Spec Bearing Face Adapter required
6. 350z HR Spec Steel Flywheel
7. 350z HR South Bend Billet Steel Flywheel
C. ANCILLARIES
To give you a complete solution, here are the ancillaries:
350z 05-07 DE Stop Tech Premium Clutch Slave Cylinder
350z 03-04 DE Stop Tech Premium Clutch Slave Cylinder
350z DE ZSP ZSP3003-DE Wilwood Heavy Duty Clutch Master Cylinder Upgrade
350z DE ZSP ZSP3004-DE Tilton Racing Clutch Master Cylinder Upgrade
350z DE Techna-Fit Stainless Steel Clutch Line
350z DE TORQEN 04-06 Chromoly Clutch Pivot Ball
350z DE TORQEN 03 Chromoly Clutch Pivot Ball
350z DE Koyo Clutch Throw Out Release Bearing
350z DE Competition Clutch Throw Out Bearing Kit
350z DE 03 350Z Upgraded Heavy Duty Clutch Fork Kit
Motul RBF 660 fluid - 1 bottle
1. 350z HR Fidanza Friction Plate Insert
Don't buy a brand new flywheel when your Fidanza Aluminum or Steel Flywheel needs changing!
2. 350z HR JWT Heavy Duty Disc Replacement
Replacement Disc only for your JWT Heavy Duty Clutch, does not include pressure plate
3. 350z HR ZSP ZSP3004-HR Tilton Racing Clutch Master Cylinder Upgrade
The OEM Nissan 350Z Clutch Master Cylinder is known to fail over time causing a mushy feel in the pedal or a pedal that will not return on its own
4. 350z HR ZSP ZSP3003-HR Wilwood Clutch Master Cylinder Upgrade
5. 350z HR ZSP ZSP2006 Heavy Duty CSC Concentric Slave Cylinder
6. 350z HR ZSP ZSP2006IH Insulated Clutch Hose
D. COMBO PACKAGES
1. 350z DE Competition Clutch, Flywheel and Fluid Combo
complete package, our most popular option for 350z DE
2. 350z DE JWT Clutch and Flywheel Combo
comes with Nismo Pilot Bushing, Chromoly Clutch Pivot Ball and Stainless Clutch Line
3. 350z DE JWT Clutch and Flywheel Kit
Nodular Iron 26lb Flywheel, 900Kg Clutch / Disc / TOB and Pilot Bearing
4. 350z DE Exedy Stage 1 Organic Clutch and Flywheel Combo
Clamp Load 2269 lbs, includes NF04 Flywheel
5. 350z DE South Bend Clutch and Flywheel Combo
with Chromoly Clutch Pivot Ball and Stainless Clutch Line, more options in the product page
1. 350z HR Competition Clutch, Flywheel and Fluid Combo
complete package, our most popular option for 350z HR
2. 350z HR JWT Clutch and Flywheel Combo
3. 350z HR JWT Clutch and Flywheel Kit
4. 350z HR South Bend Clutch and Flywheel Combo
*** PLEASE NOTE ***
For combined options (clutch + flywheel + ancillaries ) we can offer even better prices, please PM me with your requirements.
Edited by Adrian@TORQEN
  • Like 2
Could you advise on the best package/options for:
N/A daily driver
Stuck in traffic each morning
Don't want anything harder than OEM pedal feel (can live with mildy stiffer)
Do not want clutch chatter
Want to replace with as best possible performace to achieve this
Best possible ancillaries to go with above..
:thumbs:
Just had my "presumably" slave cylinder go as pulled up to services after 100mile trip went to go pushed clutch down straight to floor and no retraction. Checked clutch fluid next to brake fluid and it's empty!! Had to get recovered back home over another 100 mile trip on a lorry 😒. I have to get to work so no time to jack up and have a look but looks like reading here it's a slave cylinder.
It does have a stage 2 clutch fitted with a single mass flywheel. Done before I bought the car but they have invoices showing slave cylinder replaced only just over a year ago now. Which to me is to fast for it to go? Maybe set up wrong as had issues with smoothness of first to second and 3rd to 2nd, 1st changes almost impossible some times when cold. Was getting it checked out but now this.
I want to do work myself if possible but can't seem to find any helpful guide in where and how to change slave cylinder. Was also considering upgrading clutch hoses as well while there but again is this a easyish job or just a headache?
My 350z is a 2007 313bhp version if that helps?
