Protecting suspension components from rust.
Mack
The W brace on my car is horrendous so I ordered an after market replacement from Ultra Racing.
Looks well made but the paint has already chipped off in transit. Is there a good paint to use to protect it?
I also have replacements for the member stays all the way from New Jersey. They have very, very minor surface rust and almost look new. Again I would like to protect these against the salted roads.
Thanks
Mack
Personally for the underneath of the car I'd just use Hammerite metal paint.
Link: http://www.decoratingwarehouse.co.uk/buy/paints--coatings/metal-paints/hammerite-hammered-finish/417
You can get it in tins or spray cans, smooth or hammered finish so you can get a decent finish with it & it's supposed to give protection for at least 5 years. :thumbs:
I've used wax oil but a bit sticky. Best thing I've used tho is Hammerite. In fact done all of the car this week after seeing my w brace up on the ramps. Lol
Sexy???
And the dreaded brace.
I'll be buying one on payday.
Edited by ZZZebady
Mack you can paint Hammerite directly over the rust but it's always best to get as much off as possible ~ use a wire brush or wire drill attachment ~ if you can get it back to bear metal before you paint then that will give you the best results. ;)
