harryjackson Posted May 9, 2015 Share Posted May 9, 2015 (edited) Have a very strange noise moving the steering wheel while at low speeds eg doing a U-Turn or stationary. See video; http://s1377.photobucket.com/user/harry_jackson1/media/38753B88-7AD0-4CEB-9ED6-190900C66EC8_zpsw90ueqnp.mp4.html There's two noises in the video. The wining noise is the issue I believe the squeaky noise is the tyres Thanks Edited May 9, 2015 by harryjackson Quote Link to comment Share on other sites More sharing options...
a2orry Posted May 9, 2015 Share Posted May 9, 2015 Check the fluid level if its low look for signs of leaking also check tension of the belt . 1 Quote Link to comment Share on other sites More sharing options...
a2orry Posted May 9, 2015 Share Posted May 9, 2015 The sound on the link is very low im sure you will need power steering fluid if you go to get some its red NOT the green watery stuff. 1 Quote Link to comment Share on other sites More sharing options...
350zedd Posted May 9, 2015 Share Posted May 9, 2015 If a fluid top-up doesn't cure it, then the power steering pump will probably be knackered. Quote Link to comment Share on other sites More sharing options...
harryjackson Posted May 10, 2015 Author Share Posted May 10, 2015 Spot on guys, low power steering fluid, problem solved. Thanks guys :-) Quote Link to comment Share on other sites More sharing options...
