RobPhoboS Posted May 12, 2015 Share Posted May 12, 2015 It only leeches some power when it's on I imagine. Just fix it, you'll be punching yourself in the face during the times when you want it. I always sling my one on throughout the week to ensure it's being used, I think they can go stinky if not used (?). Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 12, 2015 Share Posted May 12, 2015 Seals go dry don't they if its not used ? Alan Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted May 12, 2015 Share Posted May 12, 2015 I'm not sure but I just remember that it's a good idea to use it at least once a week for 10 mins or so Quote Link to comment Share on other sites More sharing options...
brillomaster Posted May 12, 2015 Share Posted May 12, 2015 just keep it on all the time... on a really small car yes you can notice the difference in performance between A/C on and off - but on a zed there's plenty of power to go around, the amount of power it will be leeching is minimal. Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted May 12, 2015 Share Posted May 12, 2015 All of the above are correct for maintenance of a healthy system. The condenser is the come problem because the main fan is on the driver side and it sucks in all kinds of muck especially plant materials into the area where the condenser is and soon you have a nest of rotting plant matter leaching chemicals onto the vulnerable pipe from the condenser to the rad. It then corrodes and cracks. I was shocked how much material was bidding in there out from view. I filled the AC 3x with dye testing and the leak was no obvious until I bought uv glasses and did a meticulous search at home in the night and found only a small evidence of leak from the condenser area after I had taken the bumper off! The only way to prevent would be to be to remove the bumper and front support assembly to thoroughly clean the rad/condenser recesses every early winter!! It's too tedious to even contemplate so I guess just its replace the rad when it fails and not be stung by garages. The eBay aftermarket ones eg Nilsens fit well and way cheaper than the stealers!!!. 1 Quote Link to comment Share on other sites More sharing options...
Angrybiker Posted May 12, 2015 Share Posted May 12, 2015 Sure fire way to end up hating your car. Unless you're building a track weapon I don't see any advantage in removing the aircon Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
evilscorp Posted May 12, 2015 Share Posted May 12, 2015 Live in Scotland. . . Heater is on 364 days of the year.=( Quote Link to comment Share on other sites More sharing options...
