Kev T Posted May 7, 2015 Share Posted May 7, 2015 Over the last couple of days Abbey have fitted the new Kazz Diff along with stiffer Whiteline poly bushes and my God what a difference a locking diff makes, it totally transforms the rear end grip and can feel it push out of corners, It is so much more effective at putting the power down vs the stock VLSD, it really bears no comparison. VLSD is a paperweight by comparison, and one that over time, gets progressively worse and worse (and it doesnt start out with all that much lockup in the first place). Not cheap but so so worth it ! 4 Quote Link to comment Share on other sites More sharing options...
docwra Posted May 7, 2015 Share Posted May 7, 2015 How are you finding it refinement wise? Kaaz's can be a bit clonky and noisy sometimes Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted May 7, 2015 Share Posted May 7, 2015 Good to here Quote Link to comment Share on other sites More sharing options...
Kev T Posted May 7, 2015 Author Share Posted May 7, 2015 How are you finding it refinement wise? Kaaz's can be a bit clonky and noisy sometimes Tbf that was the one thing i was very concerned about but i am very pleasantly surprised, it is noisier than oem i can't deny it but not at all intrusive, the diff chirps a bit on tight turns and the stiffer bushes make a slight humming sound but i find the slight mechanical noises kind of endearing, the extra grip and drive easily outweigh any little niggles. I am surprised that more people have not gone down this route to improved handling. 1 Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 7, 2015 Share Posted May 7, 2015 2way or 1.5 way? Quote Link to comment Share on other sites More sharing options...
Kev T Posted May 7, 2015 Author Share Posted May 7, 2015 1.5 way adjusted to 60% Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted May 7, 2015 Share Posted May 7, 2015 It what way are the kazz diffs better /worse than the quaife diffs? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted May 7, 2015 Share Posted May 7, 2015 Is it a direct fit Kev Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 7, 2015 Share Posted May 7, 2015 I need to find somewhere to fit my 2 way still was Abbey reasonable ? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted May 7, 2015 Share Posted May 7, 2015 I think the diff will be for me before coilovers Quote Link to comment Share on other sites More sharing options...
Kev T Posted May 8, 2015 Author Share Posted May 8, 2015 Is it a direct fit Kev Yes the Kazz is direct fit on manual models of both 350 and 370. Quote Link to comment Share on other sites More sharing options...
Kev T Posted May 8, 2015 Author Share Posted May 8, 2015 StevoD, you have PM. Quote Link to comment Share on other sites More sharing options...
planetsurfer2 Posted May 8, 2015 Share Posted May 8, 2015 I've got a two way. Only issue is you have to change the diff fluid every 3000 Miles. Bit clunky at low speeds when getting to fluid change time. Transforms the car, no more pussy footing round corners. (MIne gets tracked) 1 Quote Link to comment Share on other sites More sharing options...
wmr1980 Posted May 8, 2015 Share Posted May 8, 2015 (edited) Love my mechanical diff so much better! Has a propensity to understeer initially a little, but so much more controllable through the corner and you can get on the power a lot earlier and it grips and puts power down far more efficiently. Edited May 8, 2015 by wmr1980 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted May 8, 2015 Share Posted May 8, 2015 It what way are the kazz diffs better /worse than the quaife diffs? Any thoughts on this ? Quote Link to comment Share on other sites More sharing options...
dajw Posted June 4, 2015 Share Posted June 4, 2015 Interesting — nice that its a direct fit. Personally I prefer the way Quaife do things, even though it took a while for me to get to the bottom of fitting the Quaife on my auto with LSD. The Quaifes are direct fit for every other combo (350zs and 370z manuals). I wonder whether it'd be easy to compare them? With Quaife by the way there is zero maintenance. The torque is always continuously adjusted to go to the wheel with the most grip, hence the 'automatic torque biasing' idea (that is, they don't transition quickly to a lockup state). It is purely mechanical (geared) so there is zero maintenance, and they are quiet. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted June 4, 2015 Share Posted June 4, 2015 I think quaife more than likely holds a bit more heratige behind the name That's bassed on the fact that I don't really recognise kazz so this means not a lot lol Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 4, 2015 Share Posted June 4, 2015 (edited) The Quaife is a good choice for a road car but a plate type LSD such as the Kazz is the best choice performance wise for a track car or competition car. Edited June 4, 2015 by Ewen@Clark Motorsport 1 Quote Link to comment Share on other sites More sharing options...
docwra Posted June 5, 2015 Share Posted June 5, 2015 The Quaife is a good choice for a road car but a plate type LSD such as the Kazz is the best choice performance wise for a track car or competition car. Finally Nothing to do with the names, a Quaife is a Torsen type diff that distributes power to the wheel with most grip, where the plate diffs distribute power equally when locked. I find plate diffs more predictable and they are far better for sliding about as well 2 Quote Link to comment Share on other sites More sharing options...
