350z won't start but will crank - Solved
cearnshaw85
Hi all - please move if in wrong place.
This morning my 350z wouldn't start although it was fine yesterday!
12v showing on the battery
Cranking over but won't start
I tried resetting the ECU but it didn't work
When I pumped the accelerator while cranking it almost wanted to start.
I remember I only moved it yesterday off the drive then back on in the afternoon....
I flooded the engine - what to do is put on a battery booster and hope it fires which mine did otherwise the plugs need to be removed ( an rac man can do this if you're not sure)
I thought I'd write this as I didn't find this issue anywhere on the net.
