New clutch
max
Had new clutch, slave and braided hose fitted today and I am now finding it hard to get into gear previous post say I could still have air in the system, if I turn the ignition off it seems to be a lot easier should this make a difference.
Thanks Mark.
More than likely the garage may not have got all the air out the system.
They are a bit tricky to bleed correctly if you are not conversant with the 350Z.
It is normal for gear selection to be easier with the engine switched off.
