The trackcar is dead! Long live the trackcar!
Cut and extend the arches outwards.
If you do it for both front and rear it will look awesome.
You will need to mod the bumper to keep the edges lined up.
Or copy what Docwra did with his zed.
Alternatively get a rocket bunny type or other wide body kit
Edited by GT4 Zed
Cheers Bennet, looking into a few options, not much out there thats any good or not hugley expensive so custom might be the only way to go. Dont really want to extend the steel arches with more steel as thats a heavy solution....
It also seems the tie rods on the Wisefab kit might be the wrong length, trying to resolve it via dridftworks but its very very slow going and so far the only answers Ive had are 'cant you cut it up till it fits' and 'the reason youve had to mod the wisefab for ABS is no one would drift a Z with stock engine and theyd also be able to remove ABS' - so not great......
Where I have had some good news is that after discussions with Rick from Race parts for sale I have purchased the following package.
Nismo High compression HR type heads, machined for oversize valves and high lift cams
Titanium oversized valves
Nismo GT300 double valve spring system
New seats, retainers etc
GT300 hollow cams with 268deg duration and 12.3mm lift inlet, slightly less on exhaust
And all being ported and assembled to GT300 specs by an ex Nismo engineer :D
Should compliment my NA build plans nicely! compression boost is 10.2 to 12.0, which saves me needing high comp pistons any time soon and the heads also ditch the VTC which means I wont need a new ECU to get them on and working - the UTEC should be able to get me most of the way there whilst I save for ITB's and a new ECU.
Heres some pics of the work in progress on the head porting
25398983103_d4d9ca37e0_b.jpgPorting started by ben taylor, on Flickr
25398982513_b8c153f4e6_b.jpgPorting started by ben taylor, on Flickr
25727778890_28969dc621_b.jpgPorting started by ben taylor, on Flickr
25933767391_0154af8412_b.jpgPorting started by ben taylor, on Flickr
  • Like 2
FINALLY resolved the wisefab fitment issues, had to cut the tie rods down, they use the same ones for all their kits it seems. Driftworks are amending the description to warn of this, also theyre redesigning the uprights for ABS and said I can have those when theyre done. Hopefully my mods solve it anyway. Also got my steering boots from DW (not included in wisefab kit...)
25651225234_5b2630ce37_k.jpgIMG-20160405-WA0039 by ben taylor, on Flickr
This is the fitment without spacers and an 8.5j et35 wheel. Crazy front track!!
25653321573_4b5dba1c77_k.jpgIMG-20160405-WA0067 by ben taylor, on Flickr
gonna have to space the back out quite a lot......
Also you case my new Tow strap in that pic, below you can see the mounting of it, screwed through slam panel into the chassis. winged it at trackdays so far without a towing eye.
25691296894_ed06e9d451_k.jpgIMG-20160327-WA0009 by ben taylor, on Flickr
Previously I had modded my oil cooler mounts to line it up with the bumper, this snap shows the outcome, much better!
25651220034_0340fcd699_k.jpgIMG-20160405-WA0058 by ben taylor, on Flickr
Other jobs ongoing atm are that the injectors arrived ready for when the heads do. Good old yahoo japan came to the rescue with these 650cc SARD injectors that ended up at £170 shipped and taxes paid.
26255920205_5f5d7520ea_k.jpgIMG_20160330_152246 by ben taylor, on Flickr
And Ive been working on custom seat mounts, with some pointers from Jez @ HDEV to try and get some more room my 6ft3 17st frame. Gained a lot more leg room but due to the shape of the roof Ive not gained head room. Still to work on....
26256066645_0a4be375f5_b.jpgIMG_20160402_170641 by ben taylor, on Flickr
26189809021_492155d48a_b.jpgIMG_20160402_150006 by ben taylor, on Flickr
  • 3 weeks later...
So with Cadwell looming Ive been VERY busy with the car.
Firstly some progress shots of the heads came trough, the engineer is just waiting on some more shims arriving to get the cams all fitted and theyre good to ship to me :D
26572699966_d9abaee214_c.jpgreceived_10153855533031130 by ben taylor, on Flickr
26505876722_dd05f80ca5_c.jpgreceived_10153855533261130 by ben taylor, on Flickr
26325639340_bf3d935632_c.jpgreceived_10153855532971130 by ben taylor, on Flickr
Also got the divers side seat bracket finished and the harness attached, I know wrapping it around the rear strut brace is a bit taboo, but in my opinion its safe and will do till I get a cage. Still have the passenger side to sort but I needed the car driveable to take it to Barnsley...but more on that later
26249024460_eb93706ac2_c.jpgIMG-20160415-WA0046 by ben taylor, on Flickr
26495944566_f31fa2fcc1_c.jpgIMG-20160415-WA0010 by ben taylor, on Flickr
Still umming and arring about what to do kit wise to solve the retarded wisefab fitment, think Ive sorted something rather special but need my old house to sell before I can pull the trigger on it :(
So in the mean time Tarmacsportz came to the rescue wit some cheap JDM Y0! bolt on arches which I ten made a meal of fitting, wanted to keep the bumper quick release so cut the arch so that I wasn't constantly unbolting it - well the bumper art didn't line up :( Ah well, just have to keep telling myself its legal and a temporary measure!
26495942146_3b0269c819_c.jpgIMG-20160415-WA0014 by ben taylor, on Flickr
26429560282_7b691ffdae_c.jpgIMG-20160415-WA0008 by ben taylor, on Flickr
26455782421_848055eff9_c.jpgIMG-20160415-WA0027 by ben taylor, on Flickr
25919000903_3b7e703765_c.jpgIMG-20160415-WA0021 by ben taylor, on Flickr
26495937826_0b27e890d7_c.jpgIMG-20160415-WA0044 by ben taylor, on Flickr
Then it was time to take the car to APW engineering in Barnsley for its exhaust manifolds and exhaust. I gave him the dimensions I wanted and asked it to be 95db for track and although I dont have the car back yet he has set these photos through and its looking awesome :D Getting the car back off of him Tuesday and hes kindly taking it for alignment at Slide Motorsport for me Monday.
26572699586_c58fc4b8b3_c.jpgreceived_1057221091014676 by ben taylor, on Flickr
25995631743_36abbb8a51_c.jpgreceived_1057221417681310 by ben taylor, on Flickr
26505875242_5009e4fae6_c.jpgreceived_1056758184394300 by ben taylor, on Flickr
And an obligatory burger king stop photo
26249024000_f0ae897e14_c.jpgIMG-20160415-WA0038 by ben taylor, on Flickr
Edited by fake ben taylor
Loud! Lol think my ears are bleeding..... At idle you can barely tell it's running and it seems fine for a static dB test but above 4k something changes and literally all hell breaks loose, sounds like Mike Gardners on full chat from inside the cab lol
Need to dB test it properly, but thinking of getting a bung made for cadwell just in case and then adding more silencing after cadwell if it proves to need it. It's one of those things where we won't know for sure till it's on track screaming past a dB meter :(
  • 1 month later...
Had a trackday at Cadwell recently as a shakedown of the new wisefab setup and it was a mixed bag really, some good points and some bad.
Pros: turn in and front end grip is INSANE, so so happy with it
Cons: because the kit is designed for zero caster w have pulled the heel quite far forward in the arc to get 8deg caster, this meant on big corners that really loaded up the suspension, the wheel was hitting the back of the headlight/brackets and locking the steering. NOT GOOD! This was further compounded by the longer bottom arm and, frankly, ridiculous stance which has reduced the wheel rate of the suspension from 8kg to 6kg. Also after playing with ride heights to get the suspension to a point I could drive around the issues the brakes gave up the ghost :( so that pretty much ended the day.
Heres a pretty pic to show it actually did go on track lol
26699846883_87d4596831_c.jpgFB_IMG_1464445824654 by ben taylor, on Flickr
So the plan going forwards is that I am working with APW engineering to improve the wisefab for what I want to do with it. We are going to remake the upper arm with the caster built in to pull the wheel back nearer the centre of the arch, and also contemplating shortening the lower arm. The wheel rate of the suspension is also adjustable and its currently on softest setting.
Brakes wise I got some new rear discs to go with the new rear pads I fitted just before Cadwell and some Carbon Lorraine RC6 front pads, also refreshing the fluid.
Unfortunately I have been on holiday and then taking the Z to Le Mans so the wisefab mods are waiting till after that and I am cracking on with fixing the brakes before Le Mans.
To pass the time in between Ive been taking a few pages out of DJTIMO's book and been stripping sound deadening out and also stripping the already peeling paint from the roof to vinyl wrap it. heres a few more pics.
Roll on Le Mans!
26694702083_f094325b9d_c.jpgreceived_10156973846025611 by ben taylor, on Flickr
27267527286_afbe861ac8_c.jpgreceived_10156973845925611 by ben taylor, on Flickr
27272153346_835981fdae_c.jpgreceived_10153815763278167 by ben taylor, on Flickr
27305611445_cf01254dbe_c.jpgreceived_1702974936635313 by ben taylor, on Flickr
26699163593_aa0311fdb6_c.jpgreceived_1702974929968647 by ben taylor, on Flickr
27030408240_d8d7873bcd_c.jpgreceived_1702974919968648 by ben taylor, on Flickr
27030414590_5c872f1c21_c.jpgreceived_1702974889968651 by ben taylor, on Flickr
Just the drivers side to strip then clean off all the 'goo' left by the sound deadening. Also found a little rust pocket on a seam which Im glad I caught early enough to just treat and hammerite.
27272153126_605ba114b6_c.jpgreceived_1702974873301986 by ben taylor, on Flickr
  • 1 month later...
Been a while since the last update, mostly it was a mad scamble to get the Z ready for a trip to Le Mans. Thankfully I got it all done and managed to do 1200miles in the Z across the trip. Exhaust bedded in nicely over the trip too and developed a lovely burble, Sadly also a rattle after I beached the car on a speed bump at the Chunnel!
So some pics of the work. The main issue I had with taking the Z was the horrific brake judder from Cadwell. So to solve this I thought new pads at the front, these being Carbon Lorraine RC6, for anyone tracking their car Carbon Lorraine should be the pad of choice. No deposit issues, good feedback, and stable braking from cold to ridiculously hot, you'd struggle with the disc and/or fluid long before the pad! And I also went for new discs and pads at the back, only stovk here to shift the bias to the front, its always worked for me and Ive recently reasd the Z has a lot of rear bias as stock.
Unfortunately when chenging the front pads the seals on the calipers had died so went for a full caliper rebuild, diy and my first time. To say I was nervous is an understatement!!
first step was to pull all the pistons out
27529768175_978a75f6c7_c.jpgIMG-20160607-WA0006 by ben taylor, on Flickr
nicked one of the pistons so had to sand it smooth, thankfully none had any damage to the sealing face.
26921483523_017d1e614a_c.jpgIMG-20160607-WA0014 by ben taylor, on Flickr
old seals fell to pieces
26921485303_73dc356b2e_c.jpgIMG-20160607-WA0010 by ben taylor, on Flickr
new seals
26921489043_d1a2c258c6_c.jpgIMG-20160607-WA0008 by ben taylor, on Flickr
worth mentioning pics are only of dust seals though I replaced liquid seals also.
Then I washed and screubbed the caliper and whilst the Mrs was at work used the oven to dry them.
26920446964_b2eff75b0b_c.jpgIMG-20160607-WA0018 by ben taylor, on Flickr
then put it all back together with the new pads. Rinse and repeat on the other caliper.
27402159293_a01b8cc7b0_c.jpgIMG-20160607-WA0029 by ben taylor, on Flickr
Didnt have time to strip and refresh the paint on the calipers, and to be honest I didnt feel the need as its not a show car by any means.
Took it out for a drive once finished and thankfully no leaks but struggled with bleeding the system and had an odd noise from the back, like an intermittant squeak. Haveing refreshed all the brakes I suspected wheel bearing so ordered one and booked into a friends garage for the morning we were due to leave for Le Mans. talk about last minute!
27401858834_85ecc1551c_c.jpgFB_IMG_1465897478132 by ben taylor, on Flickr
Thankfully I was right and the rear wheel bearing was KNACKERED! whilst there also used his brembo specific vacuum bleeder system and fired all the ABS solenoids and managed a better pedal feel than when I originally got the car :D
Then was the trip to Le Mans where I have few pics sadly.
27913233892_76678de4c3_c.jpgFB_IMG_1466249804885 by ben taylor, on Flickr
27735265230_97c759510c_c.jpgFB_IMG_1466454464618 by ben taylor, on Flickr
And the car was papped by a channel 4 video guy for a documentary on Le Mans, Fingers crossed it makes the final cut but the presenter was stood next to the car talking to camera :D
27735233280_778e5593ca.jpgedited_1466335700192 by ben taylor, on Flickr
Once back I parked the car up and decided it was high time I cracked on with the rear wing. Not yet finished, just one coaty of epoxy left and then design the mounts.
27311379323_28d2ddee0c_c.jpg2016-06-27_12-05-19 by ben taylor, on Flickr
awaiting gurney flap to trim the trailing edge
27331200214_f5e05c4339_c.jpg2016-06-27_08-05-14 by ben taylor, on Flickr
and said gurney ready to go
27401685093_a96aece49e_c.jpgIMG-20160629-WA0029 by ben taylor, on Flickr
And thats about it for now, hopefully before rockingham in August Ill get the wisefab arms sorted to stop it catching under compression. Not enough trackdays this year for my likming but in January I moved house and the old one still hasnt sold which has tied up all my money :(
Coming along well mate!!! Epic work on the diy carbon! 👌
Cheers bud!
Nice progress.
Just wondering if you intend on painting the bonnet cents to colour match?
I have an azure and would be curious to see how it looked.
No plans to colour match im afraid :( will be painting it black when I get round to it :)
