Hughesie90 Posted April 27, 2015 Share Posted April 27, 2015 (edited) Hi guys I haven't often paid attention to the oil pressure but recently on cold starts the needle goes right round too max at 8KKPA it'll bounce between 6-8 anytime I go over 2.5-3k revs until it's warm, once she's been running it goes back to normal! is this normal or should I replace the sensor? Edited April 27, 2015 by Hughesie90 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 27, 2015 Share Posted April 27, 2015 Its normal fella, cold oil will always make higher pressures. 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 27, 2015 Share Posted April 27, 2015 If the oil level is fine, and the pressure reads somewhere over 0 on the gauge, then every thing is fine. 2 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 27, 2015 Share Posted April 27, 2015 If the oil level is fine, and the pressure reads somewhere over 0 on the gauge, then every thing is fine. Even like 1mm over 0? thats what mine does, well, done lol. Quote Link to comment Share on other sites More sharing options...
mje-87 Posted June 1, 2015 Share Posted June 1, 2015 (edited) Hi Guys, I have a similar problem were the gauge shows 60 psi on ignition before the engine is started and then rises to 120 psi as soon as I start the car. I have given it to a local garage who has replaced the sensor with a working one from a 350z which was being stripped for parts though it still has the same problem. Is there a possibility that it could be an issue with the wiring instead of the sensor?? I have looked on many posts but every time it points to the oil pressure sensor. I find it hard to believe that the replacement sensor decided to break between being removed for the original engine and being fitted in mine. Any ideas would be much appreciated!! Edited June 1, 2015 by mje-87 Quote Link to comment Share on other sites More sharing options...
