Steel bolt snapped in aluminium.
RobPhoboS
I managed to break this bolt last year when I was trying to un-do it.
Half a turn and it broke :rant:
(so this is why I use Plusgas and the impact wrench when possible - as well as using the correct torque specs now)
Of course I don't want to be messing around with this, to end up making it worse. Any thoughts as to what I could try ? (yes it needs a clean :teeth:)
(hopefully the guy that is taking a look at my crushed brake pipe flare will be able to help)
Drill and tap it, or drill a pilot hole and try an easy out after sticking some heat on it, if you have a welder try and weld a new nut/bolt to it.
Ditch the impact gun if you have a fear of shearing bolts, you can always feel by hand when a bolt is going to shear so know when to back off and try something else
Cheers for the tips, it was done by hand, not with the impact ! :lol:
I prefer the impact due to the nature of what it's doing, sure for tightening I may start a long threaded bolt with it but always finish using the torque wrench.
I do have one of those 'easy out' extractor kits which I've used with success before, of course I just don't want to f-up the aluminium :lol:
Dude, if you fit braided lines, that bracket comes off anyway! wouldnt worry about .
It has braided lines mate (Hosetechnik) :thumbs:
It's just one of those jobs I've not gotten around to sorting out, so thought I'd check in first.
Useless. lol
