garak112 Posted April 27, 2015 Share Posted April 27, 2015 This problem is driving me crazy. I was on a drive to see the in laws a couple of months back and these lights all lit up together when on the motorway. I stopped the car at services and when I restarted it the lights were gone. A quick search of the forum revealed problems with the brake sensor so I cleaned the contacts and thought no more of it. 100 miles (several weeks for me) later and the lights all reappeared when I was approaching a junction. I decided to replace the brake pedal sensor (only £4.50) and after fitting this everything was fine for another few hundred miles when the lights reappeared on approach to a junction. They are now appearing randomly on most journeys. My brake fluid is showing max and was replaced in September, so it doesn't look like this is triggering it. One thing I had noticed is that if you start the car with your foot resting on the brake pedal it doesn't move smoothly as the vacuum comes in, it feels like it catches. It's fine at all other times. I have an OBD2 cable lying around somewhere, is there any software that I can use to connect to the car and see exactly what is triggering the lights? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 29, 2015 Author Share Posted April 29, 2015 I used something called Nissan data scan tool to connect to the ecus and it doesn't show any stored fault codes yet the problem is still happening. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Gudzy Posted April 29, 2015 Share Posted April 29, 2015 Check your brake lights are coming on properly when the pedal is pressed, that should rule out the brake pedal sensor. 1 Quote Link to comment Share on other sites More sharing options...
JonRigby Posted April 29, 2015 Share Posted April 29, 2015 Top up your brake fluid, even if its between min and max fill it to max. Mine used to show the same lights and topping up the brake fluid solved it! 1 Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 29, 2015 Author Share Posted April 29, 2015 My brake fluid is on max - was changed last September as part of the p3 service Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 29, 2015 Share Posted April 29, 2015 Double and treble check your brake fluid level. 1 Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 29, 2015 Author Share Posted April 29, 2015 It's 100% bang on the max line, I've checked a good few times. Oddly the Nissan data scan is reporting a front tight wheel speed of 130kph, but quite a few of the other sensors are reporting odd readings as well so I can't tell if this is a red herring or not. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 29, 2015 Share Posted April 29, 2015 Guess that it is not the brake fluid level then. Check your brake and high level rear light. Just do the simple checks first as a process of elimination. 1 Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 29, 2015 Author Share Posted April 29, 2015 (edited) All the brake lights are working but the rears are LEDs so am not sure if there is anything non obvious that could go wrong with these Edited April 29, 2015 by garak112 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 29, 2015 Share Posted April 29, 2015 Okay, check the ABS module switch. 1 Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 29, 2015 Author Share Posted April 29, 2015 Now I'm lost - what's that and where is it? Quote Link to comment Share on other sites More sharing options...
garak112 Posted May 2, 2015 Author Share Posted May 2, 2015 Argh! Changed the battery today because the car had been getting harder and harder to start. Drove 50 miles with no lights then on the last junction before home they all came back again. So close! Quote Link to comment Share on other sites More sharing options...
350Chris Posted May 18, 2015 Share Posted May 18, 2015 The brake pedal sensor will cost you under £15, I would do that before you end up looking at ABS units That switch was the cause of my problems - even though a garage charged me to swap the ABS unit! My brake lights would still work despite the switch being broken - it was intermittent. You can take the switches out (2 just above the pedal) and manually depress them to work out which one is broken. One switch deals with cruise control - so process of illimination to swap the brake one. They have different pin layouts... Quote Link to comment Share on other sites More sharing options...
garak112 Posted June 14, 2015 Author Share Posted June 14, 2015 Slight update - because changing the brake pedal switch seemed to work for a while I have replaced it again with a facet version rather than the non branded eurocarparts one. There is a noticeable difference in the switches - if you press the facet switch you can feel the on/off switch action (like pressing a button) whereas the other one feels smooth all the way through the action. Have done a few short journeys and haven't triggered the lights yet (on a road that always seemed to do it) but will update again. Quote Link to comment Share on other sites More sharing options...
Dannyg Posted June 15, 2015 Share Posted June 15, 2015 I had these lights come up the other month turned out to be the cam sensor had failed Replaced them both and it fixed it Quote Link to comment Share on other sites More sharing options...
garak112 Posted June 15, 2015 Author Share Posted June 15, 2015 Did you get an error when connected to a laptop? Wouldn't the eml come on fire that? Quote Link to comment Share on other sites More sharing options...
garak112 Posted July 12, 2015 Author Share Posted July 12, 2015 (edited) Hopefully the final update to this. I have done a couple of hundred miles since changing the switch (for the second time) and haven't seen the lights again. I guess this is a lesson not to buy cheap rubbish from eurocarparts... Edited July 12, 2015 by garak112 Quote Link to comment Share on other sites More sharing options...
