car splutters at 4500rpm
ronnibrown478
Ok so recently chnged clutch in my z since putting everything back together and I have doubled checked its all correct. My z will now at around 4500 rpm sputter the car will shudder and then lose revs. Any suggestions what could cause this to happen it worked fine before I changed the clutch
Hey thought id update you guys so after taking the intake apart noticed one of the clips had not quite csught the metal on one side so after repositioning the clip and tightened started it with no problems. Took it for a auick test drive and no problems thankfully
