Replacing moulded plug
bash370z
The fuse should be rated to the machine, not the plug. 13amps in the standard rating of a domestic plug, this doesn't mean the fuse within it is 13amps.
Take the fuse from the old plug and use it in the new one.
Thanks, yea I understand that its the fuse itself and not the plug. Are there different actual plugs?
Moulded plugs are found fitted on most modern appliances and can't be removed.
The only thing you can do on them is change the fuse, whereas plug tops you buy from the shop can be dismantled and rewired.
I think the OP is planning on cutting the moulded plug off and fitting a standard plug ;)
As others have said just move the fuse I've to the new plug. How do you know the moulded plug is faulty?
