Last minute tips for replacing clutch line
jollyranchers
So the car is jacked up and I have taken some covers off to access the clutch line better
Thought I would change the fluid as part of routine maintenance and install a stainless clutch line whilst I'm at it
Seen a few guides
http://www.frsport.c...-350Z_t_95.html
Any last minute tips before I remove the line from someone who has changed this before ?
How did you tackle it ?
Lots of info on bleeding on the forum here
However worried the system will 'run dry' when I drop the hose and end up in a world of hurt :lol:
Any tips appreciated especially with removing the line itself and removing the clip on one end of the line
Will prob tackle it tomorrow at some point
Also I'm assuming everyone has reused the OEM fire sleeve with the new stainless line ? , anyone insulated it further from the CAT ??
Edited by jollyranchers
just go for it, are you replacing it with a braided line? i doubt you will lose much oil if your quick, use some mole grips to clamp the old rubber pipe, take one end off, swap it to the new one, then be quick when you take the other end off lol
