nels0n Posted April 22, 2015 Share Posted April 22, 2015 Hi guys, I have had a broke window for the last few months and just recently fixed it, now having the window down i noticed a clicking sound from the drivers front wheel area. If you put the window up you cant hear it so god knows how long its been there!! After a little youtubing this video is pretty accurate to it: and my video of the noise, sorry about the background wind i wasnt sure how else to capture it: https://www.youtube.com/watch?v=pnGbBUCK4co&feature=youtu.be Would i be right in thinking its a wheel bearing going? Im not used to that sound of a bearing its normally whirring sound/droning sound. It also disappears on left turns on load and worse on right turns. I have had a look through the searches but not much comes back! Cheers Craig Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 22, 2015 Share Posted April 22, 2015 OK I recon that is rust build up on the outside of the brake disk (or rota) and it it catching the brake pad retaining spring. Wheel off - tap rust of with a hammer (gently(ish)) wheel back on - sorted Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 22, 2015 Share Posted April 22, 2015 I've got a similar sound coming from the front offside, I'll be inspecting it on Saturday. Annoying isn't it ! Quote Link to comment Share on other sites More sharing options...
garak112 Posted April 23, 2015 Share Posted April 23, 2015 If it does turn out to be the wheel bearing it is a pretty easy job, took about an hour when I did my passenger side. When mine went it made a grinding rather than clicking noise though Quote Link to comment Share on other sites More sharing options...
guBBy Posted April 23, 2015 Share Posted April 23, 2015 I just changed my wheel bearing this week as it was shot and the noise before I did it was nothing like the one in the videos. It was more of a constant drone which got really bad above 55mph. Hope that helps. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
nels0n Posted April 23, 2015 Author Share Posted April 23, 2015 Thanks guys, always a big help on here. I only asked as the guy put on the YouTube video that he changed the bearing at it worked. I'll try what Keyser suggested later and see what the outcome is! Thanks guys Quote Link to comment Share on other sites More sharing options...
Hammerz Posted April 23, 2015 Share Posted April 23, 2015 Report back mate, I've just noticed the same which might be from replacing the pads recently. Cheers Quote Link to comment Share on other sites More sharing options...
nels0n Posted April 23, 2015 Author Share Posted April 23, 2015 Ok so I've just taken the wheel off. Checked for play and nothing. I checked what Keyser said and it all seems to be fine. Still tried to clean it up a little. I'll report back in the morning when I drive to work. Strange! Quote Link to comment Share on other sites More sharing options...
RyanT Posted May 17, 2015 Share Posted May 17, 2015 Hi mate, did you ever solve this? I had this recently, seen here: https://youtu.be/s9_f87ZFT0o It happened after getting new tyres and spacers fitted. I took the wheels off, had a poke about - Made sure the disc guards weren't hitting anything and reassembled.... And it's sorted, but I'm not quite sure why! Just thought I'd message to see if you have any insight to offer! Quote Link to comment Share on other sites More sharing options...
choptop Posted May 17, 2015 Share Posted May 17, 2015 Check out CV joints Not a zed specific recommendation but usually the cause especially when on full lock. Do you notice it when doing a tight turn in car parks? Quote Link to comment Share on other sites More sharing options...
gsexr Posted May 17, 2015 Share Posted May 17, 2015 Check out CV joints Not a zed specific recommendation but usually the cause especially when on full lock. Do you notice it when doing a tight turn in car parks? That`s for front wheel drive cars mate Quote Link to comment Share on other sites More sharing options...
nels0n Posted May 17, 2015 Author Share Posted May 17, 2015 Hi mate, did you ever solve this? I had this recently, seen here: https://youtu.be/s9_f87ZFT0o It happened after getting new tyres and spacers fitted. I took the wheels off, had a poke about - Made sure the disc guards weren't hitting anything and reassembled.... And it's sorted, but I'm not quite sure why! Just thought I'd message to see if you have any insight to offer! That's exactly what happened mate and I done the same and it fixed it. Bizarre lol 1 Quote Link to comment Share on other sites More sharing options...
RyanT Posted May 17, 2015 Share Posted May 17, 2015 Ah how strange! The weird thing was for me both fronts started at exactly the same time - So it seems unlikely both front wheel bearings just happened to fail at the same time... God knows! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
