GM 350Z GT
Kaveney
Yes that's what I said im not going to touch the car just a service :)
Cams are a lot of money so that will be it engine wise ( unless I give in to a supercharger )
The car is almost finished now and all the bits I planed to do have been done just a few more bits to fit in the new year .
Alan
Sounds good, any further engine mods planned?
I hope to get a similar result, once I get my finger out and get the headers fitted.
I keep swithering about doing cams as well, typical scope creep for a car that was supposed to stay stock.
  • 3 weeks later...
Did a few bits over the holidays .
First up was a cargo net that I have been wanting for a little bit .
Then had the wheels refurbed
Still got a few more bits to do when the weather stops raining .
Alan
Small update
Changed the map lights old LED 2 type to LED board type 12 LED
Then gave the seats a good going over .
After a clean and tidy up .
Got round to changing all of the headlight lamps at the weekend bit of a pain as you have to remover the inner wing arch liner .
Thought I would upgrade all the lamps .
The main beam ones Philips extreme H7 + 130%
The dipped Xenon ones Philips extreme D2R + 50%
The side light ones are 501 50W CREE
The indicator ones silver vision
The old units with the orange indicator lamp in place .
All changed over and working
Is very easy to change the front indicator lamps and the Silver ones are only £ 8.00 .
I do love the OE rays but the brakes just fit and i mean just :)
Alan
still yet to do my de tango on the fronts and rears, yours look alot better now. such a good looking OE wheels these RAYS
Just thought I would list all of the parts I have done so far .
Nearly there just a few more bits to do .
ENGINE
OIL PAN SPACER
MISHIMOTO PERFORMANCE RADIATOR
MISHIMOTO RADIATOR FAN SHROUD KIT
RAD COLLING PANEL C/F
MOTUL COOLANT
DEI TEMP COOLANT
ENGINE GROUNDING KIT
ENGINE BRACE DAMPER
GOLD PLUG OIL DRAIN PLUG
DEI GOLD HEAT TAPE
NGK IRIDIUM SPARK PLUGS
GATES A/C + DRIVE BELT
MOTERDYNE ART PIPES EXHAUST
MILLTEK Y PIPE EXHAUST
MILLTEK CAT BACK EXHAUST
DC SPORTS 3-1 EXHAUST MANIFOLDS
H-DEV PLENUM SPACER KIT
UPREV ECU REMAP X 4
MOTORDYNE ARMAID INLET GASKET
MOTORDYNE COPPER THROTTLE BODY HEATER
2006 350Z AIR BOX
BMC PANEL FILTER
DRIVETRAIN
MOLYSLIP GEAR BOX OIL
HELL S/S CLUTCH LINE
FUCHS GEAR OIL 75W-80
QUAIFE ATB DIFF
WHITELINE REAR DIFF BUSH KIT
LUK DMF
EXEDY CLUTCH KIT
NISSAN MTF GEAR OIL
SUSPENSION
NISSAN BANANA ARMS
WHITELINE FRONT ARB
WHITELINE REAR ARB
WHITELINE FRONT HD DROP LINKS
WHITELINE REAR HD DROP LINKS
HARDRACE REAR CAMBER ARMS
HARDRACE REAR RADIUS ARMS
HARDRACE REAR LOWER ARM
HARDRACE FRONT CAMBER ARMS
HARDRACE FRONT LONG TRACK ROD ENDS
ULTRA RACING FRONT LOWER BRACE
ULTRA RACING REAR W BRACE
REAR CABIN BRACE
FRONT CORE 2 POINT BRACE
MICHELIN PILOT SUPER SPORT TYRES X 4
EGEAL PRO TRACKING
MEISTER-R ZETA R COILOVERS
SPL LOCK OUT CAMBER BOLTS
BREAKS
TORQEN BBK XXL 8POT KIT
ATE SUPER BRAKE FLUID
TORQEN S/S BRAKE LINES
EXTERIOR
XEONES PHILIPS EXTREAM X 2
PHILIPS H7 EXTREAM
SILVERTEC LAMPS
50W CREE LED SIDE LIGHTS
MICHELIN STEALTH WIPER BLADE
LED NUMBER PLATE LAMPS
HONDA SHORT AERIAL
BONNET DAMPERS
INTERIOR
MAP LIGHT LED
PINGI CAR DEHUMIDIFER X 4
ALCANTARA GEAR AND HANDBRAKE TRIM
HIDE AND SEAT RE TRIM GEAR KNOB
CARGO NET
Still very impressive massive stopping power but have the same feel as the oem brembo .
They look get too ☺
Kaveney. Was expecting to see your name down for the Woodman meet in a couple of weeks. See regional meets, south east.
Great idea Alan, you should come down! How are the brakes? Any more feedback after using those for a while? :)
Update time .
I took the car down to Abbey Motorsport to have an MOT and a few other things done .
First up was to have some Hardrace adjustable from camber arms fitted .
Then another alignment .
The front compression arms ( banana arms ) were changed last year but were showing signs of cracking again so some Superpro polyurethane were fitted .
Then for the big job .
The car is running dual coilovers front and rear ( not the more common front but separate rear shock spring set up ) and the rear strut / top mount is not designed to take the load of the shock and spring so this needed to be strengthened with seem welding
and a new plate to link the upper and lower section together and 2 braced plated per side fitted along with a good coat of Waxoyl .
Edited by Kaveney
