GM 350Z GT
Kaveney
Got another job done at the weekend .
Got my Ultra Racing front under brace in the post .
Out an ready to fit .
Installed
Bolts were a pain to remove but installed well with a nice fit .
Alan
Few more bits done at the weekend .
Motordyne copper Iso Thermal upgrade with Aramid gasket and Copper Throttle Body Heater
Removed the pelnum
Removed the old pressed steel gasket ( next to the Aramid gasket )
Few mill thicker
All in place
Then throttle body removed
New Copper Throttle Body plate
Installed on to throttle body
All put back together and checked for leeks
Edited by Kaveney
At the weekend I got round to upgrading the suspension at last .
Parts arrived from the USA . Tein springs and Tokico shocks
Old shock and spring out ( this set up has done 91K miles so a bit tired )
New Blue Tokico shock
Old vs new shock
Old vs new spring
Old vs new shock return vid
http://vid298.photobucket.com/albums/mm273/kaveney_photo/WP_20150620_0091_zpsqynrvqhm.mp4
All set up new shock and spring
Installed
Old rear shock
Old vs new
New ready to go on
Rear shock & spring installed
Have only done a few miles but its only a little firmer than stock and should be better in the corners .
Alan
Yesterday I got the car park dents on the drivers door removed that were annoying me .
Small but I could see them .
After
All pulled out with no paint or filler so im happy with that .
Alan
18mm at the front 14 at the rear I think .
Ride is around 10% more firm / harsh but handling / feel is amazing from the 91K old shock / springs .
Nice little combo for road use and some track work .
Alan
  • 3 weeks later...
Update time
Was booked in to Abbey Motorsport for some work to be done .
First was a new Exedy clutch and LUK DMF that was fitted and new gear box oil added .
Some pic of the old units that have done 92K miles .
Old DMF
Old Clutch still in ok shape but some of the rivets were getting close .
Then as the gearbox was off I had some DC sports S/S manifolds ( headers if you are from the USA ) installed .
Old log type manifold with smallish ports and uneven length tubes .
New DC Sport S/S equal length manifold
Installed .
And last to be re mapped on the dyno .
I was told that the manifolds would only give a very small gain in power and torque so the gains are about what I was expecting with the bonus of more power and torque on the whole rev range ( + 11 LB/FT at 2300 RPM ) and not moving the power and torque up all at the top of the rev range .
Alan
Another few updates over the weekend .
First was to change all x 4 Kumho tyres .
Still some good tread on them .
After lots of reading and with the car being my day to day car I went for a full set of Michelin Pilot Super Sports .
And the tracking done at the same time .
I will look to have a another alignment done soon but this will do for a few weeks .
Also received my rear brace .
Fitting was ok and went in nice and tight .
Then last was to remove my Stillen induction and replace this with a 06 350Z air box .
Stillen unit
Old air box next to 06 air box
The inlet velocity stack on the 06 air box is larger and good for a few more BHP and LB/FT
Old
New
And BMC panel filter to go with the 06 air box
All put in and tightened up .
Alan
Price came in at £ 600 all in so not to bad .
Alan
Did you get a decent price on the tyres Alan? I opted for Goodyear Eagle F1 Asymmetric 2's in the end, I couldn't stomach the stories of the Michelin's wear rate combined with their price.
