Kaveney Posted April 21, 2015 Share Posted April 21, 2015 (edited) Thought I would do a little build thread as I have had the car from September 2014 . My last car was m Rev 3 Mr2 Turbo ( link below) that did love but have all ways wanted a 350Z . http://www.pistonhea...c.asp?t=1389674 Got the car in Billingshurst in September 2014 How it was when I got it in (August 2014) Drove it with the plan on not touching or changing anything on it at all only service it . So changed the oil, gear box oil and Diff oil (September 2014) Along with some new Iridium spark pugs (September 2014) Then the last spend new AC and AUX belts (September 2014) That was going to be all I was going to do Buttttttttt it was never going to happen One week later parts arrived . K & N Typhoon was first (September 2014) Along with a H/D plenum spacer (September 2014) Then after a few weeks my rad fan stopped working (September 2014) Old unit out New Mishimoto in Some CREE LED side lights and some molly slip for the gear box (October 2014) Next was some new wiper blades (October 2014) And a new short aerial (October 2014) Headlight adjust next (October 2014) Then for the end of the month fuel sender (October 2014) The plan was then to have some HFC and a Y pipe and then have the Uprev all done at Abbey Motorsport (November 2014) Y pipe HFC And Uprev all done Low numbers to start with but good gains in the end . This little lot was a fair few £ so for the rest of the month all that was done was a LED number plate change (November 2014) Edited April 21, 2015 by Kaveney Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 Then for the end of the year a trip back up to Abbey Motorsport for some suspension parts (December 2014) x 2 banana arms Whiteline FARB set to medium Whiteline RARB set to medium And Whiteline H/D drop links This was it for 2014 so after saying the car was going to stay std rather a few upgrades have been done . Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 21, 2015 Share Posted April 21, 2015 Very nice indeed and you're definitely setting it up to be a great drivers car with the Whiteline parts. Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 So on to 2015 and after Father Christmas has given me the below (January 2015) Bonnet dampers fitted (January 2015) And a good wax (January 2015 Then on to the break parts new discs all round DS2500 pads all round S/S brake lines all round and ATE brake fluid (Feb 2015) Old discs removed Old pads removed New discs New pads New S/S lines All done and in That was it for Jan bar an MOT fail and then pass Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 So on to Feb and a quick leather seat clean and condition (February 2015) And on to sorting the boot pop up out ( February 2015) Weight removed New washers installed The new belts were squeling so needed an adjust to sort this (March 2015) Seafoam treatment was done ( March 2015) Then some more part came Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 New Stillen induction kit and Mishimoto 1.3 bar rad cap (March 2015) K & N Typhoon removed Stillen installed Old rad cap New 1.3 Bar one 1 Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 Then up to date and this month . Off again to Abbey Motorsport for a Milltek exhaust and check of the Uprev on the dyno ( April 2015) Old Exhaust New Milltek unit And the Dyno chart with another 9 BHP and 7.7 LB/FT Then on to last weekend and a clutch fluid and S/S line change and a earth kit (April 2015) Old fluid New fluid Old clutch line New S/S clutch line And wrapped in DEI heat tape And installed with some heat wrap Old earth Clean and new earths x 10 installed And that is up to date . Next moth will be a full shock and spring upgrade . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 (edited) Yes the ARB are one of the best things I have done to the car . Alan Edited April 21, 2015 by Kaveney Quote Link to comment Share on other sites More sharing options...
Leosille Posted April 21, 2015 Share Posted April 21, 2015 Sounds like you're doing all the right things, have you noticed a big difference from when you first bought it with all the new bits and bobs? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 21, 2015 Share Posted April 21, 2015 nice work Quote Link to comment Share on other sites More sharing options...
Kaveney Posted April 21, 2015 Author Share Posted April 21, 2015 Yes it drives better so much better . All the little bits make big difference . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 5, 2015 Author Share Posted May 5, 2015 Small update I fitted my MP3 holder ( best £ 4.00 I have spent ) Then top up the battery and add an extra earth . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 5, 2015 Author Share Posted May 5, 2015 Also as promised a sound clip for the Milltek exhaust ( poor phone sound but for reference it will do ) http://vid298.photobucket.com/albums/mm273/kaveney_photo/WP_20150501_0021_zps4g4m3aic.mp4 Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 11, 2015 Author Share Posted May 11, 2015 Another small update as some more parts arrived . Earthing kit to add to the smaller kit that is installed . Then wrapping the induction pipe in DEI heat tape ( did this on my old Mr2 Turbo and inlet temps came down ) And to finish off a wax with the G3 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted May 11, 2015 Share Posted May 11, 2015 Very good work . Cars looking great 1 Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 12, 2015 Author Share Posted May 12, 2015 Thanks few more bits to do then she is done . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 18, 2015 Author Share Posted May 18, 2015 Got a engine torque damper delivered form the USA on Friday Fitting was ok but space was tight . All in with earth bracket connected . There is slightly more noise / vibration in the cabin but nothing that you can feel to much . Throttle response feels a little more quicker more so in the lower gears . Alan Quote Link to comment Share on other sites More sharing options...
Karl92 Posted May 20, 2015 Share Posted May 20, 2015 looks ace, like what youve done so far dude Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted May 20, 2015 Share Posted May 20, 2015 Nice job! What we're the mishimoto fans like to fit? Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 21, 2015 Author Share Posted May 21, 2015 Posted Yesterday, 21:18 looks ace, like what youve done so far dude Thanks got some more bits coming next week ( suspension ) . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 21, 2015 Author Share Posted May 21, 2015 Posted Yesterday, 22:37 Nice job! What we're the mishimoto fans like to fit? Very easy Just wiring that takes some time . Fans are much stronger than the OEM units but do sound like a jet Alan Quote Link to comment Share on other sites More sharing options...
RyanT Posted May 21, 2015 Share Posted May 21, 2015 Very nice bud, Quick question - How did you find the seafoam? Worth doing? Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 22, 2015 Author Share Posted May 22, 2015 Very nice bud, Quick question - How did you find the seafoam? Worth doing? For £ 20 for x 2 bottles on Ebay I think so . I put one n the fuel tank 3/4 in the oil ( ran for 100 miles ) and the last bit in the crank but only a little . Alan Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted May 23, 2015 Share Posted May 23, 2015 Ive had the fans sitting in my loft 6 months ha, so really need get them done! Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 24, 2015 Author Share Posted May 24, 2015 Ive had the fans sitting in my loft 6 months ha, so really need get them done! Well worth doing . crack on:) 1 Quote Link to comment Share on other sites More sharing options...
